Port menu grayed out
OS: Debian Stretch, completely up to date.
Arduino IDE: 1.8.4
When I plug in an UNO or a Leonardo, they both register at /dev/ttyACM0, and I have no problems. When I plug in my brand new 3V Trinket, the port menu is grayed out. I’ve downloaded the appropriate board in the board manager, and everything is up to date.
I’m thinking I need to do something with ftdi drivers, modprobe… something. I don’t know.
There is no ttyACM0 or ttyUSB0 in /dev.
I am a member of the dialout group.
Here is the output of dmesg:
[ 3503.489015] usb 2-1.3: new low-speed USB device number 9 using ehci-pci
[ 3503.612325] usb 2-1.3: New USB device found, idVendor=1781, idProduct=0c9f
[ 3503.612331] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3503.612335] usb 2-1.3: Product: Trinket
[ 3503.612338] usb 2-1.3: Manufacturer: Adafruit
Output of lsusb:
Bus 002 Device 004: ID 0a5c:5802 Broadcom Corp. BCM5880 Secure Applications Processor with fingerprint touch sensor
Bus 002 Device 009: ID 1781:0c9f Multiple Vendors USBtiny
Bus 002 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
And lastly, output of tail /var/log/syslog:
Sep 21 22:52:43 strahd kernel: [ 4333.187363] usb 2-1.3: new low-speed USB device number 10 using ehci-pci
Sep 21 22:52:43 strahd kernel: [ 4333.304959] usb 2-1.3: New USB device found, idVendor=1781, idProduct=0c9f
Sep 21 22:52:43 strahd kernel: [ 4333.304965] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 21 22:52:43 strahd kernel: [ 4333.304968] usb 2-1.3: Product: Trinket
Sep 21 22:52:43 strahd kernel: [ 4333.304971] usb 2-1.3: Manufacturer: Adafruit
Sep 21 22:52:43 strahd mtp-probe: checking bus 2, device 10: "/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3"
Sep 21 22:52:43 strahd mtp-probe: bus: 2, device: 10 was not an MTP device
Any help is greatly appreciated.
Thanks!
(deleted)
spycatcher2k:
Have you been on the Adafruit site and read the tutorial on using the trinket? They cover the process quite well.
Yeah, it went into detail about downloading the board support, and that's all. The only thing it says about drivers pretty much has the Linux install in about three sentences, which boils down to "It's built in, nothing to do". Then the rest is all windows.
(deleted)
spycatcher2k:
When you double tap the reset, what happens?
It acts as though the usb cable has been disconnected and reconnected. The outputs I've pasted in just repeat themselves. Nothing new shows up in /dev.
It's a head-scratcher.
Starting to think maybe I have a bad Trinket. I'll try it on an Ubuntu machine later today and see if I have the same problem there.
(deleted)
spycatcher2k:
I'm at a loss, best nip over to the Adafruit forum and ask there, I'm sure one of their tech crew can help. :slight_smile:
Thanks for trying, I do appreciate it.
Well shoot. Here it is then:
https://forums.adafruit.com/viewtopic.php?f=52&t=46960
No Linux support for Trinket. :frowning:
"No Linux support for Trinket"
It works on some. You will not get a port because you are supposed to chose USBtinyISP from the Tools/Programmer selection.
You should also add a udev rule. See page 15 of the attached URL.
