Hello,
I'm working with an Arduino Nano 33 BLE Sense on a Linux machine, running ElementaryOS (an Ubuntu derivative). It's a Dell Latitude E5470 in case that matters. What's happening is I upload the following sketch with a library I wrote, and after finishing uploading it crashes and I need to reset it with the button the board to get the port to show up again. I know the problem is with this sketch because I can upload others. It does compile when I press verify, though.
Here's the header file for the library, TinyTrainable.h:
#ifndef TinyTrainable_h
#define TinyTrainable_h
#include "Arduino.h"
// include Arduino KNN library
#include <Arduino_KNN.h>
// TODO fix the input things and classes (3)
enum OutputMode {usb, midi, pin};
class TinyTrainable
public:
TinyTrainable(bool serialDebugging);
TinyTrainable(bool serialDebugging, byte midiChannelHex, byte midiVelocity, int midiNote1, int midiNote2, int midiNote3);
TinyTrainable(bool serialDebugging, int outputPin, long noteDuration, int noteFreq1, int noteFreq2, int noteFreq3);
template <typename T> void debugPrint(T message) {
if (_serialDebugging) {
Serial.println(message);
void setLabels(String object1, String object2, String object3);
void trainKNN(int k, int examplesPerClass, float colorThreshold);
void identify();
private:
void setupInstrument();
void setupSerial1();
void readColor(float color[]);
void setColorBuiltInLED(int color);
void midiCommand(byte cmd, byte data1, byte data2);
byte _midiChannelHex;
byte _midiVelocity;
int _outputPin;
long _noteDuration;
int _notes[3];
bool _serialDebugging;
OutputMode _outputMode;
KNNClassifier _myKNN;
float _colorReading[3];
int _k;
String _label[3];
int _previousClassification;
float _colorThreshold;
#endif
And the cpp file for the library, TinyTrainable.cpp:
#include "TinyTrainable.h"
// include Arduino library for proximity sensor
// more information at
// https://www.arduino.cc/en/Reference/ArduinoAPDS9960
#include <Arduino_APDS9960.h>
TinyTrainable::TinyTrainable(bool serialDebugging) : _myKNN(3)
_serialDebugging = serialDebugging;
_outputMode = usb;
setupInstrument();
TinyTrainable::TinyTrainable(bool serialDebugging, byte midiChannelHex, byte midiVelocity, int midiNote1, int midiNote2, int midiNote3) : _myKNN(3)
_outputMode = midi;
_midiChannelHex = midiChannelHex;
_midiVelocity = midiVelocity;
_notes[0] = midiNote1;
_notes[1] = midiNote2;
_notes[2] = midiNote3;
setupInstrument();
setupSerial1();
TinyTrainable::TinyTrainable(bool serialDebugging, int outputPin, long noteDuration, int noteFreq1, int noteFreq2, int noteFreq3) : _myKNN(3)
_outputMode = pin;
_outputPin = outputPin;
_noteDuration = noteDuration;
_notes[0] = noteFreq1;
_notes[1] = noteFreq2;
_notes[2] = noteFreq3;
setupInstrument();
void TinyTrainable::setupInstrument() {
if (_serialDebugging || _outputMode == usb) {
while (!Serial);
Serial.println("got to setupInstrument");
if (!APDS.begin()) {
while (1);
pinMode(LED_BUILTIN, OUTPUT);
pinMode(LEDR, OUTPUT);
pinMode(LEDG, OUTPUT);
pinMode(LEDB, OUTPUT);
// start with everything off
digitalWrite(LED_BUILTIN, LOW);
digitalWrite(LEDR, HIGH);
digitalWrite(LEDG, HIGH);
digitalWrite(LEDB, HIGH);
_previousClassification = -1;
void TinyTrainable::setupSerial1() {
Serial1.begin(9600);
// desired baudrate
uint32_t baudrate = 0x800000;
// pointer to the memory address that stores the baudrate
uint32_t *pointerBaudrate = ( uint32_t * )0x40002524;
// replace the value at the pointer with the desired baudrate
*pointerBaudrate = baudrate;
void TinyTrainable::setLabels(String object1, String object2, String object3) {
_label[0] = object1;
_label[1] = object2;
_label[2] = object3;
void TinyTrainable::trainKNN(int k, int examplesPerClass, float colorThreshold) {
_k = k;
_colorThreshold = colorThreshold;
for (int currentClass = 0; currentClass < 3; currentClass++) {
setColorBuiltInLED(currentClass);
// Ask user to show examples of each object
for (int currentExample = 0; currentExample < examplesPerClass; currentExample++) {
debugPrint("Show me an example of:");
debugPrint(_label[currentClass]);
// Wait for an object then read its color
readColor(_colorReading);
// Add example color to the k-NN model
_myKNN.addExample(_colorReading, currentClass);
// Wait for the object to move away again
while (!APDS.proximityAvailable() || APDS.readProximity() == 0) {}
void TinyTrainable::setColorBuiltInLED(int color) {
// turn everything off
if (color == 0) {
digitalWrite(LEDR, LOW);
} else if (color == 1) {
digitalWrite(LEDG, LOW);
} else if (color == 2) {
digitalWrite(LEDB, LOW);
void TinyTrainable::identify() {
debugPrint("Let me guess your object");
// Classify the object
int classification = _myKNN.classify(_colorReading, _k);
debugPrint("You showed me:");
debugPrint(_label[classification]);
setColorBuiltInLED(classification);
if (classification != _previousClassification) {
switch (_outputMode) {
case usb:
debugPrint(classification);
case midi:
midiCommand(_midiChannelHex, _notes[classification], _midiVelocity);
case pin:
tone(_outputPin, _notes[classification], _noteDuration);
_previousClassification = classification;
void TinyTrainable::readColor(float colorReading[]) {
int red, green, blue, proximity, colorTotal = 0;
// Wait for the object to move close
while (!APDS.proximityAvailable() || APDS.readProximity() > 0) {}
// Wait until we have a color bright enough
while (colorTotal < _colorThreshold) {
// Sample if color is available and object is close
if (APDS.colorAvailable()) {
// Read color and proximity
APDS.readColor(red, green, blue);
colorTotal = (red + green + blue);
_colorReading[0] = red;
_colorReading[1] = green;
_colorReading[2] = blue;
debugPrint(colorTotal);
debugPrint(_colorReading[0]);
debugPrint(", ");
debugPrint(_colorReading[1]);
debugPrint(", ");
debugPrint(_colorReading[2]);
debugPrint("\n");
// send 3 byte midi message
void TinyTrainable::midiCommand(byte cmd, byte data1, byte data2) {
Serial1.write(cmd);
Serial1.write(data1);
Serial1.write(data2);
The ino file, TinyTrainable.ino:
TinyTrainable myInst(true);
// TinyTrainable myInst(true, 0x99, 127, 38, 39, 42);
// TinyTrainable myInst(true, 9, 100, 250, 450);
Serial.println("got to setup");
myInst.debugPrint("Arduino k-NN color classifier");
myInst.setLabels("Object 1", "Object 2", "Object 3");
myInst.trainKNN(5, 10, 0.5); // TODO make these constants at the top
myInst.identify();
I'll reply to this with the error - I'm hitting the word limit.
