I used an Uno and a Yun shield to connect the Uno to the Internet but after doing all the necessary changes that i need to do, even after successfully selecting the board type when i wanted to change the port, it wouldn’t open. It cannot detect any port hence my code cannot be uploaded. I even tried to update firmware but if it can’t detect anything then how can the firmware be updated.
A possible reason according to some people is because the arduino I am using is the later version of the previous where the yun doesn’t support to that of the previous die to an ic or chip that was present on the previous version Unos.
However I wannt to know the legitimacy of that conclusion and a possible solution to detect the port for my code to be uploaded ASAP.
Did you try a different USB cable or verify that the USB cable you're using works for data on a different device? You may have a damaged or charge-only cable.
I tried uploading a code on the uno itself and it shows me the same error it did for the YUN. And the port still can't be selected but the lights of the arduino is on as usual
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "192.168.1.120": The system cannot find the file specified.
