Port not working
Hello. I'm just starting out on using Arduinos. I have an Arduino Nano but I can't seem to communicate with it. I've tried it with two computers. On one, the Port under Tools is greyed out. I've tried fixing this but the instructions on how to fix this don't match the options I see on the screen. On my other computer, I get a programmer is not responding error. Can anyone tell me how to fix this problem?
Regards, Stuart
If the port option is greyed your port and cable are not really working. Try connecting the cable to another USB port on your system.
I've managed, somehow, to get the port to not be greyed out, but I get the same error now as I get on the other computer.
Correction, the error is not the same, it is stk500_getsync() attempt 9 of 10: not in sync: resp=0x00 .
I now get the same not in sync error on both computers.
Try new nano and check same problem occurs or not
Have you tried the various options under tools -> processor in the IDE?
Your post is lacking details:
Which OS?
What does your OS think about the board? In Windows that would be: what happens in device manager when you connect the board?
Which version of the IDE?
To answer your questions: Windows 10 on both computers. On both computers, the device is acknowledged when plugged it. On the desk top, in Device Manager, "Other devices" appears with "USB serial" under it. This has the yellow "!" symbol. Looking further into it, it says that there is no driver installed. I've tried installing drivers, but the system doesn't recognise them as drivers.
When I plug it into the laptop, it acknowledges the device, and "Ports" appears in Device Manager. Under that is "USB-SERIAL CH340 (COM4)" Under that, it reports that the device is working properly. When I try and upload, I get the not in sync error. With the desktop, I get the further error of "programmer not responding". I've tried two Nanos, and neither of them work.
The IDEs are 1.8.10 on the desk top, 1.8.13 on the lap top.
My first step would be to load one of the LED blink examples and verify the board and programming is working.
That's what I have tried to do, with both computers.
I order to gather more information that might help us to troubleshoot your problem, I'm going to ask you to post the full output from the laptop when you upload in verbose mode.
Please do this:
  1. Select File > Preferences from the Arduino IDE's menus.
  2. Uncheck the checkbox next to Show verbose output during: [ ] compilation
  3. Check the checkbox next to Show verbose output during: [ ] upload.
  4. Click the OK button.
  5. Attempt an upload, as you did before.
  6. After the upload fails, you'll see a button on the right side of the orange bar Copy error messages. Click that button. This copies the full output to the clipboard.
  7. Open a forum reply here by clicking the Reply button.
  8. Click the </> icon on the post composer toolbar. This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  9. Press Ctrl+V. This will paste the error output from the upload into the code block.
  10. Move the cursor outside of the code tags before you add any additional text to your reply.
  11. Click the Reply button to post the output.
Arduino: 1.8.10 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\Stuart\AppData\Local\Temp\arduino_build_777816/sketch_may02a.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM1
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xfe
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Here is the output from the desktop computer.
Select Tools > Processor > ATmega328P (Old Bootloader) from the Arduino IDE's menus and then try uploading again.
Arduino: 1.8.10 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b57600 -D -Uflash:w:C:\Users\Stuart\AppData\Local\Temp\arduino_build_777816/sketch_may02a.ino.hex:i
         Using Port                    : COM1
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf2
With old bootloader.
Select Tools > Port > COM4 from the Arduino IDE's menus and try uploading again.
COM1 is the only option.
Is COM4 still shown in Windows Device Manager?
Only COM1 appears.
Do you have any idea about why it appeared before and it doesn't appear now?
