Port program with EEPROM.h calls from Arduino Uno to Portenta
I wrote a sketch which reads a scale using sparkfun's 7802 and their library, moves a motor using the accelstepper.h library, and reading an encoder via a DB9 connector. I wanted to increase the speed at which I was reading everything so I ordered a portenta to try and do this in parallel.
I cannot run my orginal program because the sparkfun 7802 library uses #include< EEprom.h> and the portenta does not have an EEprom.
Where should I go from here?
#include <AccelStepper.h>
#include <MultiStepper.h>
// Integrates ScaleWeight, MotorSetPVA, Temp
#include <Wire.h>
//#include <EEPROM.h>                                       //Needed to record user settings
#include "SparkFun_Qwiic_Scale_NAU7802_Arduino_Library.h" // Click here to get the library: http://librarymanager/All#SparkFun_NAU8702
#include <SparkFunTMP102.h>
//Encoder Stuff
const int pinA = 2, DRO_B = 3, phaseLookup[] = {0,-1,1,-1,1,0,-1,-1,-1,1,0,1,1,1,-1,0};
volatile bool A = false, B = false, updated = false;
volatile int counter = 0, phase = 0;
//Temp Sensor
TMP102 sensor0;
//Scale
NAU7802 myScale; // Create instance of the NAU7802 class
// EEPROM locations to store 4-byte variables
#define LOCATION_CALIBRATION_FACTOR 0 // Float, requires 4 bytes of EEPROM
#define LOCATION_ZERO_OFFSET 10       // Must be more than 4 away from previous spot. Long, requires 4 bytes of EEPROM
bool settingsDetected = false;        // Used to prompt user to calibrate their scale
// Create an array to take average of weights. This helps smooth out jitter.
#define AVG_SIZE 4
float avgWeights[AVG_SIZE];
byte avgWeightSpot = 0;
//Stepper stuff
#define STEPPER_DIR_PIN 9
#define STEPPER_STEP_PIN 8
int Position;
int Velocity;
int Acceleration;
// Define stepper and the pins the will use
AccelStepper stepper(AccelStepper::DRIVER, STEPPER_STEP_PIN, STEPPER_DIR_PIN);
  Serial.println("Motor and Scale and Temp and Encoder");
  Wire.begin();
  Wire.setClock(400000); // Qwiic Scale is capable of running at 400kHz if desired
//Encoder  pinMode(pinA, INPUT);
  pinMode(DRO_B, INPUT);
  attachInterrupt(digitalPinToInterrupt(pinA), trig, CHANGE);
  attachInterrupt(digitalPinToInterrupt(DRO_B), trig, CHANGE);
//Temp Sensor init
    if(!sensor0.begin())
    Serial.println("Cannot connect to TMP102.");
    Serial.println("Is the board connected? Is the device ID correct?");
    while(1);
  Serial.println("Connected to TMP102!");
 // set the number of consecutive faults before triggering alarm.
  // 0-3: 0:1 fault, 1:2 faults, 2:4 faults, 3:6 faults.
  sensor0.setFault(0);  // Trigger alarm immediately
  // set the polarity of the Alarm. (0:Active LOW, 1:Active HIGH).
  sensor0.setAlertPolarity(1); // Active HIGH
  // set the sensor in Comparator Mode (0) or Interrupt Mode (1).
  sensor0.setAlertMode(0); // Comparator Mode.
  // set the Conversion Rate (how quickly the sensor gets a new reading)
  //0-3: 0:0.25Hz, 1:1Hz, 2:4Hz, 3:8Hz
  sensor0.setConversionRate(2);
  //set Extended Mode.
  //0:12-bit Temperature(-55C to +128C) 1:13-bit Temperature(-55C to +150C)
  sensor0.setExtendedMode(0);
  //set T_HIGH, the upper limit to trigger the alert on
  sensor0.setHighTempF(85.0);  // set T_HIGH in F
  //sensor0.setHighTempC(29.4); // set T_HIGH in C
  //set T_LOW, the lower limit to shut turn off the alert
  sensor0.setLowTempF(84.0);  // set T_LOW in F
  //sensor0.setLowTempC(26.67); // set T_LOW in C
//Scale init
  if (myScale.begin() == false)
    Serial.println("Scale not detected. Please check wiring. Freezing...");
    while (1)
  Serial.println("Scale detected!");
  readSystemSettings(); // Load zeroOffset and calibrationFactor from EEPROM
  myScale.setSampleRate(NAU7802_SPS_320); // Increase to max sample rate
  myScale.calibrateAFE();                 // Re-cal analog front end when we change gain, sample rate, or channel
  Serial.print("Zero offset: ");
  Serial.println(myScale.getZeroOffset());
  Serial.print("Calibration factor: ");
  Serial.println(myScale.getCalibrationFactor());
  // Stepper initialize
  stepper.setMaxSpeed(2500.0);
  stepper.setAcceleration(4000.0);
//Temp Stuff
float temperature;
  boolean alertPinState, alertRegisterState;
sensor0.wakeup();
  // Stepper Stuff
  readSerialInput();
  stepper.run();
  //Loop Print
  loopPrint();
void loopPrint(){
  //DRO
        Serial.print("DRO position: ");
        Serial.print(String(counter));
//Weight
        float currentWeight = myScale.getWeight();
        Serial.print("    Weight: ");
        Serial.print(currentWeight, 2); // Print 2 decimal places
//Temp
      Serial.print("   Temperature: ");
      float temperature = sensor0.readTempF();
      Serial.println(temperature);
delay(250);
// Sets Stepper position, Velocity, and acceleration
void readSerialInput()
  if (Serial.available() > 0)
    // read the incoming string:
    String incomingString = Serial.readStringUntil('$'); // read the incoming byte:
    String Command = incomingString.substring(0, 3);
  if (Command == "DRO")
      Serial.println(String(counter));
    // If command starts with POS, set Position
    if (Command == "POS")
      Position = incomingString.substring(3).toInt();
      Serial.print("Position set to: ");
      Serial.println(Position);
      stepper.moveTo(Position);
    if (Command == "VEL")
      Velocity = incomingString.substring(3).toInt();
      Serial.print("Velocity set to: ");
      Serial.println(Velocity);
      stepper.setMaxSpeed(Velocity);
    if (Command == "ACC")
      Acceleration = incomingString.substring(3).toInt();
      Serial.print("Acceleration set to: ");
      Serial.println(Acceleration);
      stepper.setAcceleration(Acceleration);
if (Command == "TMP")
      Serial.print("Temperature: ");
      Serial.print(temperature);
    if (Command == "WEI")
      if (myScale.available() == true)
        Serial.print("Weight: ");
        Serial.println(currentWeight, 2); // Print 2 decimal places
        if (settingsDetected == false)
          Serial.print("\tScale not calibrated. Press 'c'.");
    if (Command == "TAR")
      myScale.calculateZeroOffset();
    if (Command == "CAL")
      calibrateScale();
//Encoder Function
void trig()
  A = digitalRead(pinA);
  B = digitalRead(DRO_B);
  phase <<= 1;
  phase |= A;
  phase <<= 1;
  phase |= B;
  phase &= 0xF;
  counter += phaseLookup[phase];
  //updated = true;
// Gives user the ability to set a known weight on the scale and calculate a calibration factor
void calibrateScale(void)
  Serial.println(F("Scale calibration"));
  Serial.println(F("Setup scale with no weight on it. Press a key when ready."));
  while (Serial.available())
    Serial.read(); // Clear anything in RX buffer
  while (Serial.available() == 0)
    delay(10); // Wait for user to press key
  myScale.calculateZeroOffset(64); // Zero or Tare the scale. Average over 64 readings.
  Serial.print(F("New zero offset: "));
  Serial.println(F("Place known weight on scale. Press a key when weight is in place and stable."));
  Serial.print(F("Please enter the weight, without units, currently sitting on the scale (for example '4.25'): "));
  // Read user input
  float weightOnScale = Serial.parseFloat();
  myScale.calculateCalibrationFactor(weightOnScale, 64); // Tell the library how much weight is currently on it
  Serial.print(F("New cal factor: "));
  Serial.println(myScale.getCalibrationFactor(), 2);
  Serial.print(F("New Scale Reading: "));
  Serial.println(myScale.getWeight(), 2);
  recordSystemSettings(); // Commit these values to EEPROM
// Record the current system settings to EEPROM
void recordSystemSettings(void)
  // Get various values from the library and commit them to NVM
  EEPROM.put(LOCATION_CALIBRATION_FACTOR, myScale.getCalibrationFactor());
  EEPROM.put(LOCATION_ZERO_OFFSET, myScale.getZeroOffset());
// Reads the current system settings from EEPROM
// If anything looks weird, reset setting to default value
void readSystemSettings(void)
  float settingCalibrationFactor; // Value used to convert the load cell reading to lbs or kg
  long settingZeroOffset;         // Zero value that is found when scale is tared
  // Look up the calibration factor
  EEPROM.get(LOCATION_CALIBRATION_FACTOR, settingCalibrationFactor);
  if (settingCalibrationFactor == 0xFFFFFFFF)
    settingCalibrationFactor = 0; // Default to 0
    EEPROM.put(LOCATION_CALIBRATION_FACTOR, settingCalibrationFactor);
  // Look up the zero tare point
  EEPROM.get(LOCATION_ZERO_OFFSET, settingZeroOffset);
  if (settingZeroOffset == 0xFFFFFFFF)
    settingZeroOffset = 1000L; // Default to 1000 so we don't get inf
    EEPROM.put(LOCATION_ZERO_OFFSET, settingZeroOffset);
  // Pass these values to the library
  myScale.setCalibrationFactor(settingCalibrationFactor);
  myScale.setZeroOffset(settingZeroOffset);
  settingsDetected = true; // Assume for the moment that there are good cal values
  if (settingCalibrationFactor < 0.1 || settingZeroOffset == 1000)
    settingsDetected = false; // Defaults detected. Prompt user to cal scale.
I am also looking into a solution comparable to EEPROM for the Arduino Portenta H7.
I found that the Portenta has 8mb of SDRAM and it can be accessed with the SDRAM.h library. I can't find the documentation but below are a few links that may help:
