Port to different library
I have some code which works fine on a Nordic board - it basically receives some commands via BLE - then displays various symbols on a screen.
I need to port this onto an ESP32-S3 board - BUT - from the example code I've found, the libraries and their commands are different, and I'm struggling to replicate what it's doing.
Any help much appreciated - or even an Example that Receives data and does something with it...I can take it from their.
The original code; (with specifics and display code removed)
#define BLE_DEBUG false
// Libraries
#include <SPI.h>
#include <STBLE.h>
#include "BLEtypes.h"
#include <TinyScreen.h>
// Used by Arduino - not sure what for
#if defined (ARDUINO_ARCH_AVR)
#define SerialMonitorInterface Serial
#elif defined(ARDUINO_ARCH_SAMD)
#define SerialMonitorInterface SerialUSB
#endif
// BLE Variables
BLEConn BLEConnection;
BLEServ UARTService;
BLEChar TXchar;
BLEChar RXchar;
#define UARTServiceUUID "6E400001-B5A3-F393-E0A9-E50E24DCCA9E"
#define UARTRXcharUUID  "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
#define advertiseName  "mydevice"
//Global variables used in the code
unsigned long lastScreenChange = 0;         // Keeps track of millisecond counter (since board reset) so we know when to refresh to Home page
unsigned long refresh = 5 * 1000;           // Number of milliseconds after which screen will refresh to Home screen (5 * 1000 = 5 seconds)
// Define the space Create a structure that is big enough to contain the 2D array of pixels.
// The "valid" variable is set to "true" once the structure is filled with actual data for the first time.
bool valid = false;
typedef struct {
  boolean valid;
  char pixels[64][96];                    // px=0-96; py=0-63 when drawing
} Signature;
Signature signature;                 // Create a "Signature" variable and call it "signature"
// Other Variables
char bytein;                    // used to hold Sig byte in
int b1,b2;                      // Values of the 2 halves of the byte coming in
int midimage = 0;               // Flag to use to indicate mid image receiving
int outline = 0;                // Defines what the Outline to the logo should be - 0-none; 1=Green; 2=Red square
int px = 0;                     // Counters
int py = 0;                     // counters
// Initial Setup Function - run once on startup or reset
void setup(void) {
  display.begin();
  SerialMonitorInterface.begin(115200);
  while (!SerialMonitorInterface && millis() < 5000);
  delay(100);
  SerialMonitorInterface.print("Doing setup");
  BLEsetup(&BLEConnection, advertiseName, BLEConnect, BLEDisconnect);
  addService(&UARTService, UARTServiceUUID);
  addCharacteristic(&UARTService, &RXchar, UARTRXcharUUID, CHAR_PROP_WRITE_WITHOUT_RESP);
  enableNotifications(&RXchar, RXCharUpdate);
  displayHomeScreen();
  SerialMonitorInterface.print("Done setup");
// Main Loop that runs forever or until it resets
  BLEProcess();             //Process any ACI commands or events- main BLE handler.
  handleConnection();
  if (BLEConnection.isConnected) {}
  if (lastScreenChange && (millis()-lastScreenChange > refresh)) {
// ************** BLE Connection Functions
// Connect to BLE
void BLEConnect() {
  SerialMonitorInterface.print("---------Connected to device: ");
  for (int i = 5; i > 0; i--) {
    if (BLEConnection.connectedAddr[i] < 16)SerialMonitorInterface.print('0');
    SerialMonitorInterface.print(BLEConnection.connectedAddr[i], HEX);
    SerialMonitorInterface.print('-');
  if (BLEConnection.connectedAddr[0] < 16)SerialMonitorInterface.print('0');
  SerialMonitorInterface.println(BLEConnection.connectedAddr[0], HEX);
// Handle when ble is connected
bool handleConnection() {
  if (!BLEConnection.isConnected && !BLEConnection.isAdvertising) {
    advertise(advertiseName, UARTServiceUUID);
    SerialMonitorInterface.println("Advertising");
  return false;
// BLE Disconnect
void BLEDisconnect() {
  SerialMonitorInterface.println("---------Disconnected");
// *********** End of BLE Functions ********* //
// ***** Main Event Listener that Receives and processes input data over BLE
void RXCharUpdate(byte * newData, byte length) {
    // Message Received
  if (length>3 && !strncmp ("XXX", (char*)newData, 3)) {
    SerialMonitorInterface.println("VIG Received");
    midimage = 0;                                   // Close off recieving any more image  if we were mid image
    displaySomething();
    return;                                          // Return and wait for another input
  // Drop through if we've processed the input OR it's not a recognised block of data
// *************End of the Main listener function
// Display
void displaySomething() {
 // Displays various things
Is it code that you wrote yourself, or from a 3rd party?
Hi awneil
Most of the logic in it and display stuff is mine. The basic BLE connectivity was from an Arduino example sketch - and it's that part I need to change
The new examples use a different library which seem to do things differently and doesn't give me the same options to process the input data.
