portable arduino for app testing only?
I sometimes do aruino dev on the road, and unless I'm missing something, there's no way to run a sketch without an arduino attached to the computer, for testing purposes. So I've been packing a spare uno, but now some of my sketches, especially with debugging messages going to serial, are exceeding the uno's sram, and I've had to start packing my mega2560. Now that's already a big item to throw in the laptop bag, and I don't want to damage it. I've got a couple Nanos that I might pack instead, but they don't have the sram either.
So I got to thinking… is there anyone that makes a very small portable unit based on the mega2560, for just runtesting? Ideally I'd like to see something in a package the size of a Nano, with a USB A connector right on the board. It might end up looking just like a USB flash drive. I don't need pin access, short of maybe the reset button. (but not really) Just something I can plug in, upload, and run with serial window open to see that it's up and executing properly etc. But I haven't seen anything in a small form factor of any sort that uses the Due, Mega, or Mega2560, for the larger sram. ideas? maybe a kickstarter/new product idea for someone?
How about a '1284, plug on an FTDI Basic for USB/Serial?
16K SRAM too.
No picture showing FTDI attached to post from this computer, have to wait until I get home.
http://www.crossroadsfencing.com/BobuinoRev17/
Assemble with only the FTDI header if no IO is needed.
http://www.pjrc.com/teensy/index.html
Not a Mega but certainly more than an Uno...
http://www.pjrc.com/store/teensy.html
Half the Flash all of the SRAM of a Mega...
http://www.pjrc.com/store/teensypp.html
Makes the Mega look like a dinosaur (ARM processors instead of AVR)...
http://www.pjrc.com/store/teensy3.html
http://www.pjrc.com/store/teensy31.html
that Teensy++ looks very nice actually. If it had an actual usb connector to plug directly into the usb port on my computer, that'd be absolutely perfect. (no need to screw around with a usb cable, just plug it in like a flash drive) Know of any that direct plug into a computer?
I suppose I could try to hack a regular usb connector. Might need to borrow the steadier hands a local that enjoys soldering those cat whiskers, and slather a bit in some hot melt glue for durability :wink:
Also, are the teensy 3.0 and 3.1 compatible with the Arduino IDE?
virtual1:
They are. And so are CrossRoads' boards.
Were I in your shoes I would use a 3" USB cable. I think I bought the ones I have from USB Gear.
I believe they are currently not compatible with 1.5.x (probably because the library layout is in flux). From past experiences with Paul Stoffregen's work I suspect they are "highly compatible" with Arduino IDE 1.0.x.
Ahh, glad I asked then. I'd like to stick with the current IDE for now to reduce confusion on my part. Those do look nice though, 64k sram, 256k prom.
I suppose i could go with a short usb cable, but I'd really prefer the simplicity of a direct connect. I'm a bit surprised that none of these small arduinos have that as an option.
Well, if you're embedding them into something, onboard USB is not really needed.
Bootload, download, and away you go. Use right angle header to make it a little more compact.
This isn't for embedding, this is simply for a mobile test bed. In a perfect world, I'd be able to toss a Teensy in my pocket in the morning. If I'm on the train headed to work and want to pull out my laptop to do a little debugging, I don't have to go dig a mega out of my laptop bag (if I even bothered to bring it) as well as go find a usb cable from my bag, and sit there with the laptop on my lap and the mega laying on the floor as I try to work. It would be so much better to just plug in a teensy like a flash drive and go. I could tolerate a teensy in my pocket, but I'd rather not add to the bulk with a cable. And certainly not a mega :wink:
virtual1:
I'd like to stick with the current IDE...
The current IDE is 1.0.x (one-point-zero).
Then get one... From past experiences with Paul Stoffregen's work I suspect they are highly compatible with Arduino IDE 1.0.x.
The 1284 board was designed for embedded use tho.
However, one of these adapters and the 1284 with a right angle female header ...
Eh, pinouts are not quite right tho.
Be easy enough to design tho.
oh ok. not sure why I was thinking I was using 1.5, I just figured 1.5 was current and I had the most recent. I'm using 1.0.5 .
ok then I suppose it's worth a shot. Is there any reason not to get a Teensy 3.1? (surprised they didn't add more EEPROM) It looks like all-around improvements from 1, 2, and 3.0
I think take the 3.3V pin off this one, would be all set:
http://www.ebay.com/itm/CP2102-USB-2-0-to-TTL-UART-Module-6Pin-Serial-Converter-STC-Replace-FT232-Module-/161103531292?pt=LH_DefaultDomain_0&hash=item258284cd1c
Still, neater to have as all 1 unit.
but if the teensy's have a usb on them already, why bother going through that?
virtual1:
The pins sink / source less current than an AVR processor.
3.3 volt device (also a benefit).
The processor is more complicated. If you like low-level programming you will have significantly more to learn (I believe the datasheet is roughly five times larger).
Not available in a DIP package.
You are more likely to run into Arduino API bugs.
Well, more of a different animal than a better animal.
