I am using a Portable Arduino IDE in a modified scratch programming software. When I install the software with the Portable Arduino IDE into the Program Files (x86) folder, then the permissions on the Portable/preferences.txt file get changed from “user-modify” to “user-read and execute” and the Portable Arduino IDE will not start. In this case the Portable Arduino IDE hangs after preparing boards and closes with this error java.io.FileNotFoundException: C:\Program Files (x86)\QpetScratch\Arduino\portable\preferences.txt (Access is denied)
If I manually change the permission of the preferences.txt back to user-modify after installing into the Program Files (86) directory, then the Portable Arduino IDE starts file. But I need an automated installation for this software without having to change the permissions manually after installing.
The Portable Arduino IDE is in widespread use I think, so I wonder how others have overcome this problem.
How can you let the Portable Arduino IDE preferences.txt file keep its user-modify settings after installing it into the Porgram Files (x86) directory?
Thanks, Drew
