PortB not working for Pin8 and Pin9
Hi all.
I trying to use PortB to write to Pin8-13, as described in the documentation:
This simple code, will make Pin 10,11,12,13 flash:
void setup(void)
	DDRB = B11111111;
void loop(void)
	PORTB = B11110000;
	PORTB = B00000000;
This works! :slight_smile:
Now I want to make Pin 8 and Pin 9 flash as well, so I modify the code in the mail loop to:
PORTB = B11111100;   % <=== Notice the change
PORTB = B00000000;
Nothing changes :frowning:
When using DigitalWrite, Pin 9 and 10 are working just fine.
What can be wrong?
I'm using Arduino Mega.
PORTB = B11111100;  % <=== Notice the changeHave you got the order of the bits the wrong way round ?
Should that be
PORTB = B00111111;   % <=== Notice the change
Nope :slight_smile:
I have also verified that, by flipping all the pins high. I really don't understanding what could cause this.
According to Arduino port mapping Arduino digital pin 8 maps to PB0 and digital pin 8 maps to PB1
Where are bits 0 and 1 in B00111111 ?
This is what I have tried:
void setup(void)
	// Set portB as output.
	DDRB = B11111111;
// Main
void loop(void)
	PORTB = B11111111;
	PORTB = B00000000;
Only pin 10, 11, 12 and 13 is working as expected. Pin 8 and 9 is not switching between high and low.
As stated in the original post "PORTB = B11110000" makes pin 13, 12, 11 and 10 go high. That seems to be the opposit of the documentation you found. If changing to "PORTB = B00110000", then only pin 11 and 10 are high.
********** EDIT **********
Hmm... So for the Arduino Mega, port B is:
PB 0 => Pin 53
PB 1 => Pin 52
PB 2 => Pin 51
PB 3 => Pin 50
PB 4 => Pin 10
PB 5 => Pin 11
PB 6 => Pin 12
PB 7 => Pin 13
I guess that is my issue... :slight_smile:
Now you tell us.....
