PortD problem
I am doing a electronic project for an class I’m taking. The professor only allowed to use Arduino Digital Pins as a counter. It’s connect to a DAC0832. Using 8 bits.
What I want to do is quite simple. I want the 8 digital pins (Binary) go from 0 to 255 then from 255 to 0 .
What’s happening is that they are setting high till 255 then it’s going back directly to 0. It’s not decreasing from 255 to 0. What’s wrong in this code?
   DDRD = 255;
  PORTD++;
  if ( PORTD == 255){
    while ( PORTD != 0 ){
      PORTD--;
You are not showing us all the code.
It's not decreasing from 255 to 0. What's wrong in this code?
Why do you think it is not decreasing?
   DDRD = 255;
  PORTD++;
  delay(100);
  Serial.println(PORTD);
  if ( PORTD == 255){
      PORTD--;
      delay(100);
cattledog: Why do you think it is not decreasing?
   DDRD = 255;
void loop() {     PORTD++;   delay(100);     if ( PORTD == 255){     while ( PORTD != 0 ){       PORTD--;       Serial.println(PORTD);       delay(100);       }   } }
The wave I am gettting in the output. It only goes up till 255 then suddenly go back to zero. I think the problem may be somewhere else . I'm simulating with proteus. The code seems ok , right?
The serial printout patched into your code shows numbers going up and down..
