Hello!
Yes, i know that it was just Warnings, and it doesnt matter. But if you read all the error code, you'll see that there is a lot of issues with the sketch "thingproperties.h" and "ArduinoIoTCloud":
(sorry, i didn't include the code, here it is)
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "Arduino Portenta H7 (M7 core)"
WARNING: library ArduinoIoTCloud claims to run on samd, esp8266 architecture(s) and may be incompatible with your current board which runs on mbed architecture(s).
WARNING: library Arduino_ConnectionHandler claims to run on samd, esp32, esp8266 architecture(s) and may be incompatible with your current board which runs on mbed architecture(s).
WARNING: library ArduinoECCX08 claims to run on samd, megaavr architecture(s) and may be incompatible with your current board which runs on mbed architecture(s).
In file included from c:\users\angel\onedrive\documentos\arduino\libraries\arduinoiotcloud\src\property\propertycontainer.h:25:0,
from C:\Users\angel\OneDrive\Documentos\Arduino\libraries\ArduinoIoTCloud\src/cbor/CBORDecoder.h:29,
from C:\Users\angel\OneDrive\Documentos\Arduino\libraries\ArduinoIoTCloud\src/ArduinoIoTCloud.h:32,
from sketch\thingProperties.h:1,
from C:\Users\angel\OneDrive\Desktop\TFG\PortentaIoT_sep12a\PortentaIoT_sep12a\PortentaIoT_sep12a.ino:19:
c:\users\angel\onedrive\documentos\arduino\libraries\arduinoiotcloud\src\property\types/automation/CloudTelevision.h: In member function 'virtual void CloudTelevision::setAttributesFromCloud()':
c:\users\angel\onedrive\documentos\arduino\libraries\arduinoiotcloud\src\property\types/automation/CloudTelevision.h:229:39: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
setAttribute((int&)_cloud_value.pbc);
c:\users\angel\onedrive\documentos\arduino\libraries\arduinoiotcloud\src\property\Property.h:45:42: note: in definition of macro 'setAttribute'
#define setAttribute(x) setAttributeReal(x, getAttributeName(#x, '.'))
c:\users\angel\onedrive\documentos\arduino\libraries\arduinoiotcloud\src\property\types/automation/CloudTelevision.h:230:39: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
setAttribute((int&)_cloud_value.inp);
In file included from sketch\thingProperties.h:1:0,
sketch\thingProperties.h: In function 'void initProperties()':
C:\Users\angel\OneDrive\Documentos\Arduino\libraries\ArduinoIoTCloud\src/ArduinoIoTCloud.h:100:64: warning: 'void ArduinoIoTCloudClass::addPropertyReal(float&, arduino::String, permissionType, long int, void (*)(), float, void (*)(Property&))' is deprecated: Use addProperty(property, Permission::ReadWrite) instead. [-Wdeprecated-declarations]
#define addProperty( v, ...) addPropertyReal(v, #v, __VA_ARGS__)
sketch\thingProperties.h:18:16: note: in expansion of macro 'addProperty'
ArduinoCloud.addProperty(ligth, READ, 30 * SECONDS, NULL);
C:\Users\angel\OneDrive\Documentos\Arduino\libraries\ArduinoIoTCloud\src/ArduinoIoTCloud.h:108:10: note: declared here
void addPropertyReal(float& property, String name, permissionType permission_type = READWRITE, long seconds = ON_CHANGE, void(*fn)(void) = NULL, float minDelta = 0.0f, void(*synFn)(Property & property) = CLOUD_WINS) __attribute__((deprecated("Use addProperty(property, Permission::ReadWrite) instead.")));
sketch\thingProperties.h:19:16: note: in expansion of macro 'addProperty'
ArduinoCloud.addProperty(pressure, READ, 30 * SECONDS, NULL);
sketch\thingProperties.h:20:16: note: in expansion of macro 'addProperty'
ArduinoCloud.addProperty(temperatura, READ, 30 * SECONDS, NULL);
In file included from C:\Users\angel\OneDrive\Desktop\TFG\PortentaIoT_sep12a\PortentaIoT_sep12a\PortentaIoT_sep12a.ino:22:0:
C:\Users\angel\OneDrive\Documentos\Arduino\libraries\Adafruit_BMP280_Library/Adafruit_BMP280.h: At global scope:
C:\Users\angel\OneDrive\Documentos\Arduino\libraries\Adafruit_BMP280_Library/Adafruit_BMP280.h:40:17: error: conflicting declaration 'arduino::SPIClass SPI'
extern SPIClass SPI; /**< Forward declaration of SPI object */
In file included from C:\Users\angel\OneDrive\Desktop\TFG\PortentaIoT_sep12a\PortentaIoT_sep12a\PortentaIoT_sep12a.ino:21:0:
C:\Users\angel\OneDrive\Documentos\ArduinoData\packages\arduino-beta\hardware\mbed\1.2.2\libraries\SPI/SPI.h:64:25: note: previous declaration as 'arduino::MbedSPI SPI'
extern arduino::MbedSPI SPI;
Multiple libraries were found for "WiFi.h"
Used: C:\Users\angel\OneDrive\Documentos\ArduinoData\packages\arduino-beta\hardware\mbed\1.2.2\libraries\WiFi
Not used: C:\Users\angel\OneDrive\Documentos\Arduino\libraries\WiFiNINA
Not used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\libraries\WiFi
exit status 1
Error compiling for board Arduino Portenta H7 (M7 core).
option enabled in File -> Preferences.
What do you think?
Thanks and have a nice day!
PD: I'm gonna try your libraries and i'll share if it work or doesnt for me! Thanks a lot for that also!!
