Hey everyone,
I need to permanently save data for user settings. I've been using the included QSPI-Flash to achieve this and so far it has worked great.
The Problem:
I own a total amount of 5 Arduino Portenta H7.
- 1 Portenta H7 (bought in 2021) + 1 Portenta H7 Lite (bought in April 2022). I'll refer to those as "older" boards.
- 3 Portenta H7 Lite (bought in December 2022). I'll refer to those as "newer" boards.
When I tried to Flash my existing code (which worked on the "older" boards) to the "newer" boards, everything except the QSPI-Flash worked. I simply couldn't read, store or erase data. This problem occurs on all three (!) of the "newer" boards.
In order to find the error I made this simple sketch, based on THIS tutorial:
//QSPI-Flash test
#include "QSPIFBlockDevice.h"
#include "MBRBlockDevice.h"
using namespace mbed;
#define BLOCK_DEVICE_SIZE 1024*8 //Define 8KB Partition Size
#define PARTITION_TYPE 0x0B //Define Partition Type as FAT32
void setup(){
HAL_Init();
int initStatus=0;
uint64_t eBS=0, pBS=0, rBS=0; //Erase-BlockSize | Program-BlockSize | Read-BlockSize
while(!Serial); //Wait for Serial port
//Create Block Device
QSPIFBlockDevice root(PD_11, PD_12, PF_7, PD_13, PF_10, PG_6, QSPIF_POLARITY_MODE_1, 40000000);
MBRBlockDevice blockDevice(&root, 1);
//Block-Device initialisation
if(blockDevice.init() != 0 || blockDevice.size() != BLOCK_DEVICE_SIZE){
Serial.println("\n\nPartitioning block device...\n");
blockDevice.deinit();
MBRBlockDevice::partition(&root, 1, PARTITION_TYPE, 0, BLOCK_DEVICE_SIZE);
initStatus = blockDevice.init(); //<-- Returns -4002 when using "newer" boards.
//Get Block-sizes
eBS = blockDevice.get_erase_size();
pBS = blockDevice.get_program_size();
rBS = blockDevice.get_read_size();
//Write returned Values to Serial
Serial.println("-------- Results of QSPI Block Device Test --------");
Serial.println("Init status: " + String(initStatus));
Serial.println("Erase block size: " + String((int)eBS));
Serial.println("Program block size: " + String((int)pBS));
Serial.println("Read block size: " + String((int)rBS));
Serial.println("---------------------------------------------------");
//Not used in this sketch :)
void loop(){
I compiled this code both in Arduino IDE 1.8.19 and VSCode (PlatformIO), both yield the same results:
Serial monitor output using an "older" Portenta H7 Lite:
Serial monitor output using a recently bought Portenta H7 Lite:
As you can see, when I'm trying to initialize the blockDevice, it returns an error code (-4002). As a result, I can't erase, program or read data.
To Summarize:
- QSPI-Flash works on Portenta H7 boards I've bought more than half a year ago (April 2022)
- QSPI-Flash doesn't work on Portenta H7 boards I've bought in December 2022
- Initialization returns an Error-Code (-4002) on "newer boards"
Questions:
- Has the Hardware changed (different Pins for QSPI, etc.)?
- Is there anyone who has/had the same problem?
Any help is greatly apprechiated
Thanks,
Thomas
