Hello all ,
and another problem occurs to me with the arduino h7 machine control and i hope someone can help me.
So iam programming a arduino h7 machine control and the codeworks fine. The board is powered with a extern 24V power supply. And i can connect and disconnect the serial connection (cable) like i want and nothing happens to the board. Its running like it should.
So far so good. I integrated a watchdog for restarts if something goes wrong.
.h:
# include <mbed.h>
#include <Watchdog.h>
using namespace mbed;
using namespace rtos;
Watchdog &watchdog = Watchdog::get_instance();
setup()-function:
watchdog.start(8000);
loop()-function:
watchdog.kick();
so i only inserted this codesnippets.
And now the board restarts after the defined 8seconds which are triggered when i pull out the serial cable to the PC. When i don`t do that, the code runs like intended.
Is there a context between watchdog or mbed object and a serial connection?
I have no idea.
Thanks
Sarah
