Here's a full sketch that reads all of the PMIC chip's I2C registers on the H7:
#include <Wire.h>
// Define an array of each register address (There's gaps in the readable register adresses so just define the ones that are meaningful/used)
const uint8_t REGISTER_ADDRESSES_PMIC[] = { 0x00, 0x01, 0x02, 0x06, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F, 0x10, 0x18, 0x19, 0x1A, 0x20, 0x21, 0x22, 0x24, 0x25, 0x26, 0x28, 0x29, 0x2A, 0x30, 0x32, 0x33, 0x34, 0x35, 0x36, 0x38, 0x39, 0x3A, 0x3B, 0x3C, 0x3E, 0x3F, 0x40, 0x41, 0x42, 0x48, 0x4A, 0x4C, 0x4D, 0x4F, 0x50, 0x52, 0x53, 0x58, 0x59, 0x5A, 0x5B, 0x5F, 0x60, 0x61, 0x62, 0x63, 0x64, 0x65, 0x67, 0x68, 0x69, 0x6A, 0x6B, 0x6F };
const uint8_t REGISTER_ADDRESSES_CHARGER[] = { 0x00, 0x02, 0x04, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0D, 0x0E, 0x0F, 0x11, 0x12, 0x14, 0x15, 0x16, 0x18, 0x19, 0x1A, 0x1B, 0x1C, 0x1D, 0x1E, 0x1F };
const uint8_t REGISTER_ADDRESSES_OTP[] = { 0x1C, 0x1D, 0x1E, 0x1F, 0x20, 0x21, 0x22, 0x23, 0x24, 0x25, 0x26, 0x27, 0x28, 0x29, 0x2A, 0x2B, 0x2C, 0x2D, 0x2E, 0x2F, 0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37 };
Wire1.begin(); // Initialize I2C communication on Wire1 (Doesn't work on "Wire")
Serial.begin(9600); // Initialize Serial communication
while (!Serial) { // Wait for serial port to connect
delay(100);
// Read the PMIC registers
Serial.println("--- PMIC Registers --- ");
int check = sizeof(REGISTER_ADDRESSES_PMIC);
Serial.print("PMIC array size: ");
Serial.println(check); // Should be 66
for (uint8_t i = 0; i < sizeof(REGISTER_ADDRESSES_PMIC); i++) {
byte data = readFromRegister(0x08, REGISTER_ADDRESSES_PMIC[i]);
Serial.print("Register:,0x");
Serial.print(REGISTER_ADDRESSES_PMIC[i], HEX);
Serial.print(",Value:,");
Serial.print(data, HEX);
Serial.print(",Binary:,");
printBinary(data); // Print binary representation of the byte
Serial.println("");
Serial.println("------------------");
delay(100);
// Read the Charger registers
Serial.println("--- Charger Registers --- ");
check = sizeof(REGISTER_ADDRESSES_CHARGER);
Serial.print("Charger array size: ");
Serial.println(check); // Should be 24
for (uint8_t i = 0; i < sizeof(REGISTER_ADDRESSES_CHARGER); i++) {
byte data = readFromRegister(0x08, REGISTER_ADDRESSES_CHARGER[i] + 0x80); // Charger registers ave an "offset" of 0x80
Serial.print(REGISTER_ADDRESSES_CHARGER[i], HEX);
Serial.println("");
// Read the OTP registers
Serial.println("--- OTP Registers --- ");
check = sizeof(REGISTER_ADDRESSES_OTP);
Serial.print("OTP array size: ");
Serial.println(check); // Should be 28
//Enable OTP reading
//KEY1
uint8_t OTPCmd = 0x15;
writeToRegister(0x08, 0x6F, OTPCmd); // Device address, register address, data
//KEY2
OTPCmd = 0x50;
writeToRegister(0x08, 0x9F, OTPCmd); // Device address, register address, data
//TEST_REG_KEY3
OTPCmd = 0xAB;
writeToRegister(0x08, 0xDF, OTPCmd); // Device address, register address, data, data
//RC REQ 16MHz
OTPCmd = 0x01;
writeToRegister(0x08, 0x6B, OTPCmd); // Device address, register address, data
//OTP is indirect read, via register 0xC4 = FMRADDR and 0xC5 = FRMDATA
for (uint8_t i = 0; i < sizeof(REGISTER_ADDRESSES_OTP); i++) {
writeToRegister(0x08, 0xC4, REGISTER_ADDRESSES_OTP[i]); // Device address, register address, data
delay(2);
byte data = readFromRegister(0x08, 0xC5); // Charger registers ave an "offset" of 0x80
Serial.print(REGISTER_ADDRESSES_OTP[i], HEX);
Serial.println("");
while(1){}
void writeToRegister(uint8_t deviceAddress, uint8_t registerAddress, uint8_t data) {
Wire1.beginTransmission(deviceAddress); // Start communication with device on Wire1
Wire1.write(registerAddress); // Address of the register to write to
Wire1.write(data); // Write the data
Wire1.endTransmission(); // End communication
byte readFromRegister(uint8_t deviceAddress, uint8_t registerAddress) {
byte data;
Wire1.write(registerAddress); // Address of the register to read from
Wire1.endTransmission(false); // Send restart to keep connection alive
// Request 1 byte from the device
Wire1.requestFrom(deviceAddress, 1);
if (Wire1.available()) {
data = Wire1.read(); // Read the byte
return data;
void printBinary(byte b) {
for (int i = 7; i >= 0; i--) {
Serial.print((b >> i) & 1);
