I try to connect UART/Serial connection to my board but i read that only 3.3v is allowed to connect. saddly my device work on 5-6v Serial.
Can someone confirm that Portenta H7 can only work with 3.3 volt devices ?
i dont want to burn it quick if something goes wrong.
thank you . I will try that but maybe someone already try or have some data what voltage range can be used on portenta H7 because i cant find any details . So probably also for this board if i want to program i2c eeprom have to get also level converter becasue they work on 5v?
See the datasheet https://www.st.com/resource/en/datasheet/stm32h747ag.pdf
chapter 6.2 "Absolute maximum rating"
According to above, the maximum input voltage for most Potenta H7 pins is 4.0v, so you definitely need to use logic level converter
