Portenta H7 : USB Audio Device
I try to use Portenta with USB as an USB Audio device.
There are few files in Arduino LIB, e.g. "USBAudio.h", "PluggableAudioAudio.h" and "USBAudio.cpp".
I copied the files "USBAudio.h" and "USBAudio.cpp" under my project - compile it - and it is compile clean. Great.
I try to use this USBAudio (marked as "experimental" in comments).
I do this in my sketch:
    USBAudio audio(true, 44100, 2, 44100, 2);
    static uint8_t buf[177];
    while (true) {
        if (!audio.read(buf, sizeof(buf))) {
            memset(buf, 0x1f, sizeof(buf));
        if (audio.write_ready())
            audio.write(buf, sizeof(buf));
What works so far?
I can see the input (microphone) as well as the output (speaker) as an "Mbed Audio" device enumerated. Cool - the USB enumeration works.
What does not work
  • It looks like I can only chose 44.1 KHz in Portenta H7 code. When 48 KHz is tried - I do not see anymore the sample frequency settings in the Windows audio drivers. It looks to me: other than 44.1 KHz fails already on enumeration (guessing due to a different set of USB descriptors needed and Ardunio code is not generating/not sending it for other sample rates properly).
  • no data is transferred: I use tool Audacity to record or play sound. Audacity can crash. Or nothing happens. Tool does not progress. I do not see my values expected as 0x1F1F (constant DC value filled). Instead: nothing. It looks like the audio device on Portenta H7 does not send anything.
  • This "loopback" example does not work. My guess: Portenta H7 does not receive and does not send anything, after USB enumeration was OK.
Another issue:
I thought, this USB Audio comes out on the user USB, the breakout USB-A connector. And I need a second USB cable to connect my USB Audio with host. But not true. It uses also USB-C.
But instead: it uses also the USB-C connection. And it kills my USB-C UART there. So, I lose control to the board, I cannot talk to Portenta H7 via USB-C anymore.
A bit obvious (reconfiguring the USB-C now just and only for USB Audio) - but not nice. I would not be able to live with this drawback. I need my UART available all the time. Instead: put the USB Audio on the breakout board USB-A connector.
Who does have any luck or experience on this topic?
  • How to setup a second, separate USB connection for USB Audio? (not losing USB-C UART, using user USB-A on breakout is file)
  • How to see that this USB Audio is working? At least I want to see my buffers filled with data come in on host (working as an USB Audio Input on host, like a microphone).
I am also a bit confused about the "flow control":
When I see this code, running in endless loop, to read and write USB buffer (with Audio samples) - how does it synchronize with USB? Actually, every 1 ms a sample buffer is ready or due to be sent. But this code seems to run full speed, not in sync with USB Audio device. How can it work?
How could I be notified if a new sample buffer is available or ready to queue again?
(code looks really "experimental").
Who could help to setup an USB Audio Device which works on a host? (and transfers audio samples, at least in one direction)
And how to keep my UART via USB-C working when setting up USB Audio?
thinking about... - is the INT handler for USB missing?
(I do not see where and how the USB device INT is setup, esp. the vector to the USB INT handler)
But it should not be the case: otherwise even sending the USB Enumeration (the USB device descriptors) should not work.
"hmmmm" - I hope I can make it working ...
Hello, I am just learning about Mbed and unfortunately can't answer your question but perhaps you could help answer one for me:
Where can I find the library you refer to, specifically "PluggableAudioAudio.h"?
Thanks!
Bob
