Hi! My Portenta H7 tells me to update the wifi firmware. However, when looking for the example code, this appears to be missing:
I'm using Arduino IDE 1.8.19. I've tried to reinstall the board, did not change anything. Does someone know where to find the correct example code? Thanks!
Have you seen the following page?
In this article, we will go through a step-by-step process on how to get the latest Wi-Fi firmware on your Portenta H7 board. Before updating the WiFi firmware, make sure the bootloader is up-to-da...
Yes I've seen that page. Also discovered that the wifi firmware update sketch is located elsewhere in the menu:
So that solves my issue
As this is a question about the Portenta I've moved it to the Portenta section of the forum.
Thanks,
system
Closed
December 6, 2022, 8:27pm
5
