Hello everyone, I need some help.
I have a Portenta H7 and a Nextion display and would like to read serial strings and also output texts on the display.
The strange thing is when I connect it to an Arduino Mega via interface 0.1 then it works.
I would like to use UART 1 or UART 2 with the Portenta.
Can someone maybe show me a code how to read continuously without errors? I've never seen that before.
So i will paid via Paypal if you help me
Thank you
// +++++++++++++ INPUTS FROM DISPLAY TO MEGA ++++++++++++
// SERIELLE BUTTON/TEXT KOMMUNIKATION INFO
// Interlock EXT1 = "BT98ON" "BT98OFF"
// Interlock EXT2 = "BT99ON" "BT99OFF"
// Interlock RESET = "ERESET"
// Interlock 1-8 Select = "IL18ON" "IL18OFF"
// Interlock 9-16 Select = "IL916ON" "IL916OFF"
// Interlock 16-24 Select = "IL1724ON" "IL1724OFF"
// Interlock 24-32 Select = "IL2532ON" "IL2532OFF"
// Interlock ALL ON/OFF "ALLON" "ALLOFF"
// SYSTEM RESTART = "SReset"
// LED SYSTEMTEST = "TLEDON" "TLEDOFF"
// +++++++++++++ OUTPUT FROM ARDUINO TO MEGA ++++++++++++
// PAGE 2 t1.txt HAUPTSTATUS ANZEIGE
// PAGE 2 t4.txt KEYSWITCH ON/OFF
//SETUP CONTROLLER
// GENERAL INPUTS
int ESTOPIN= 4; // EINGANG ESTOP IN FÜR MELDUNG
int KEYSWITCH=5; // EINGANG KEYSWITCH IN FÜR MELDUNG
int RESETEXT=6; // EINGANG RESET TASTE INTERN
// GENERAL OUTPUTS
int OUT1= 14; // AUSGANG RELAIS 1 SEKTION 1-8
int OUT2= 15; // AUSGANG RELAIS 2 SEKTION 9-16
int OUT3= 16; // AUSGANG RELAIS 3 SEKTION 17-24
int OUT4= 17; // AUSGANG RELAIS 4 SEKTION 25-32
int OUT5= 18; // AUSGANG RELAIS 5 RESET
int OUT6= 19; // AUSGANG
int OUT7= 20; // AUSGANG
int OUT8= 21; // AUSGANG
// STARTE COMMUNICATION
Serial.println("SERIAL 1 BEGINN");
// DEFINIERTE E/As
pinMode(ESTOPIN, INPUT_PULLUP);
pinMode(KEYSWITCH, INPUT_PULLUP);
pinMode(RESETEXT, INPUT_PULLUP);
pinMode(OUT1, OUTPUT);
pinMode(OUT2, OUTPUT);
pinMode(OUT3, OUTPUT);
pinMode(OUT4, OUTPUT);
pinMode(OUT5, OUTPUT);
pinMode(OUT6, OUTPUT);
pinMode(OUT7, OUTPUT);
pinMode(OUT8, OUTPUT);
//AUFRUF PROGRAMM
if(Serial.available()){ //++++++++++++++++++++++++++++++++++++++++++
String data_from_display=""; // LADE SCHNITSTELLE UND SCHREIBE STRING
delay(50); //++++++++++++++++++++++++++++++++++++++++++
data_from_display += char(Serial.read());
ESTOPIN = digitalRead(4); //+++++++++++++++++++++++++++++++++++++++++++
KEYSWITCH = digitalRead(5); // EINLESEN VON EINGÄNGEN
RESETEXT= digitalRead(6); //+++++++++++++++++++++++++++++++++++++++++++
if(KEYSWITCH == LOW){ // FUNKTION MELDUNG KEYSWITCH OFF/ON
Serial.print("t1.pco=65504"); //+++++++++++++++++++++++++++++++++++++++++++
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print("t1.txt=\"OFF\""); // SENDE TEXT AN DISPLAY KEYSWITCH OFF
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
else if(KEYSWITCH == HIGH){ // FUNKTION KEYSWITCH ON
Serial.print("t1.pco=1024");
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print("t1.txt=\"ON\""); // SENDE TEXT AN DISPLAY KEYSWITCH ON
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
else if(ESTOPIN == LOW){ // FUNKTION MELDUNG NOTAUS
delay(30);
digitalWrite(OUT5, LOW);
delay(30);
Serial.print("b1.bco=65504");
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print("b1.pco=63488"); // SENDE TEXT AN DISPLAY EMERGENCY STOP // TASTER NEGATION
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print("t1.pco=63488");
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print("t1.txt=\"EMERGENCY STOP!\""); // SENDE TEXT AN DISPLAY EMERGENCY STOP // TASTER NEGATION
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
else if(ESTOPIN == LOW && KEYSWITCH == HIGH){
delay(30);
delay(30);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
else if(ESTOPIN == HIGH){
Serial.print("SYSSTATE.pco=63488");
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print("SYSSTATE.txt=\"\""); // LEERE TEXT WENN KEIN NOTAUS // TASTER NEGATION
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
else if(ESTOPIN == HIGH && KEYSWITCH == LOW){ // FUNKTION MELDUNG SYSTEM STARTBEREIT
Serial.print("t1.pco=1024"); //++++++++++++++++++++++++++++++++++++++++++++++
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print("t1.txt=\"SYSTEM READY!\"");
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print("t1.txt=\"WAIT FOR KEY!\"");
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
else if(ESTOPIN == HIGH && KEYSWITCH == HIGH){ // FUNKTION MELDUNG LASER EMISSION OFF/ON
Serial.print("t1.pco=65504"); //++++++++++++++++++++++++++++++++++++++++++++
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print("t1.txt=\"LASER EMISSION ON!\"");
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
void sendData(String data_from_display){ //EMFANGENE DATEN VON DISPLAY STRING
if(data_from_display =="IL18ON"){ // SEKTION ANWAHL BUTTON INTERLOCK 1-8 ON
delay(30);
digitalWrite(OUT1, HIGH);
delay(30);
else if (data_from_display =="IL18OFF"){ // SEKTION ANWAHL BUTTON INTERLOCK 1-8 OFF
delay(30);
digitalWrite(OUT1, LOW);
delay(30);
else if (data_from_display =="IL916ON"){ // SEKTION ANWAHL BUTTON INTERLOCK 9-16 ON
delay(30);
digitalWrite(OUT2, HIGH);
delay(30);
else if (data_from_display =="IL916OFF"){ // SEKTION ANWAHL BUTTON INTERLOCK 9-8 OFF
delay(30);
digitalWrite(OUT2, LOW);
delay(30);
else if (data_from_display =="IL1724ON"){ // SEKTION ANWAHL BUTTON INTERLOCK 17-24 ON
delay(30);
digitalWrite(OUT3, HIGH);
delay(30);
else if (data_from_display =="IL1724OFF"){ // SEKTION ANWAHL BUTTON INTERLOCK 17-24 OFF
delay(30);
digitalWrite(OUT3, LOW);
delay(30);
else if (data_from_display =="IL2532ON"){ // SEKTION ANWAHL BUTTON INTERLOCK 25-32 ON
delay(30);
digitalWrite(OUT4, HIGH);
delay(30);
else if (data_from_display =="IL2532OFF"){ // SEKTION ANWAHL BUTTON INTERLOCK 25-32 OFF
delay(30);
digitalWrite(OUT4, LOW);
delay(30);
else if (data_from_display =="ALLON"){ // SEKTION ANWAHL INTERLOCK ALLE ON
delay(30);
delay(30);
else if (data_from_display =="ALLOFF"){ // SEKTION ANWAHL INTERLOCK ALLE OFF
delay(30);
delay(30);
