Portenta Machine Control With Python
I just Started with the Portenta (Machine Control), im a big fan of Python specially when i already have a running version of the program in python
im able to upload in the the H7 with openMV and use the onboard LED,
now im looking for documentation ( if it is posible ) to get in too the "Machine control board"
Check with your source for the Portenta (Machine Control), I would expect to be part of the package when you purchased it. The schematic is published at this: https://content.arduino.cc/assets/AKX00032-schematics.pdf that should have all the information you need.
import pyb # Import module for board related functions
from pyb import Pin
gpio0 = Pin('PI6', Pin.OUT_PP, Pin.PULL_NONE)
gpio1 = Pin('PH9', Pin.OUT_PP, Pin.PULL_NONE)
gpio2 = Pin('PJ9', Pin.OUT_PP, Pin.PULL_NONE)
while True:
  gpio0.on()
  pyb.delay(100)
  gpio0.off()
  gpio1.on()
  pyb.delay(100)
  gpio1.off()
  gpio2.on()
  pyb.delay(100)
  gpio2.off()
Thanks That was easier then it looked
maping the "DIGITAL OUTPUTS" was easy to understand but im still unable to understand the other ports, input, I/O, Analog
// EDIT i found the anolog read
adc0 = ADC(Pin('PC3'))
adc1 = ADC(Pin('PC2'))
adc2 = ADC(Pin('PA1'))
print("Analog value0:", adc0.read())
print("Analog value1:", adc1.read())
print("Analog value2:", adc2.read())
i made some progress able to read 2nd until 8th digital pin with that
but during testing the 24V+ fell out of my hand and arced somewhere on the board 3v3 power is gone even directly connected to the H7 there is nothing, it will be a couple days until the new one arrives
I2C_ADDRESS = 0x23
# Initialize I2C communication
i2c = SoftI2C(sda=Pin('PH8'), scl=Pin('PH7'), freq=100000)
# Read the input states from the GPIO expander
def read_input_states():
    i2c.writeto(I2C_ADDRESS, bytes([0]))  # Send command to read input states
    input_states = i2c.readfrom(I2C_ADDRESS, 1)  # Read 3 bytes for input states
    return input_states
input_pins = ["Input 05", "Input 04", "Input 03", "Input 3",  "Input 02",  "Input 01",  "Input 07",  "Input 06",  "Input 8"]
while True:
  input_states = read_input_states()
  print("Input states:", input_states)
  # Interpret input states
  active_inputs = []
  for bit_position in range(8):
         if input_states[0] & (1 << bit_position):
             active_inputs.append(input_pins[bit_position])
  if active_inputs:
         print("Active input pins:", active_inputs)
  else:
         print("No active input pins.")
im currently reading down a rabit hole of how to get it to work when the new board arrives
after digging in the the arduino IDE lib "Arduino_MachineControl.h"
and reading all the files i think i have all the different addresses
#define TCA6424A_ADDRESS_ADDR_LOW   0x22 // address pin low (GND)
#define TCA6424A_ADDRESS_ADDR_HIGH  0x23 // address pin high (VCC)
#define TCA6424A_DEFAULT_ADDRESS    TCA6424A_ADDRESS_ADDR_LOW
#define TCA6424A_RA_INPUT0          0x00
#define TCA6424A_RA_INPUT1          0x01
#define TCA6424A_RA_INPUT2          0x02
#define TCA6424A_RA_OUTPUT0         0x04
#define TCA6424A_RA_OUTPUT1         0x05
#define TCA6424A_RA_OUTPUT2         0x06
#define TCA6424A_RA_POLARITY0       0x08
#define TCA6424A_RA_POLARITY1       0x09
#define TCA6424A_RA_POLARITY2       0x0A
#define TCA6424A_RA_CONFIG0         0x0C
#define TCA6424A_RA_CONFIG1         0x0D
#define TCA6424A_RA_CONFIG2         0x0E
#define TCA6424A_AUTO_INCREMENT     0x80
#define TCA6424A_LOW                0
#define TCA6424A_HIGH               1
#define TCA6424A_POLARITY_NORMAL    0
#define TCA6424A_POLARITY_INVERTED  1
#define TCA6424A_OUTPUT             0
#define TCA6424A_INPUT              1
#define TCA6424A_P00                0
#define TCA6424A_P01                1
#define TCA6424A_P02                2
#define TCA6424A_P03                3
#define TCA6424A_P04                4
#define TCA6424A_P05                5
#define TCA6424A_P06                6
#define TCA6424A_P07                7
#define TCA6424A_P10                8
#define TCA6424A_P11                9
#define TCA6424A_P12                10
#define TCA6424A_P13                11
#define TCA6424A_P14                12
#define TCA6424A_P15                13
#define TCA6424A_P16                14
#define TCA6424A_P17                15
#define TCA6424A_P20                16
#define TCA6424A_P21                17
#define TCA6424A_P22                18
#define TCA6424A_P23                19
#define TCA6424A_P24                20
#define TCA6424A_P25                21
#define TCA6424A_P26                22
#define TCA6424A_P27                23
for anyone who will ever need it
using python to control outputs (will make an edit soon to add the input)
from pyb import Pin,ADC
from machine import SoftI2C
import time
I2C_ADDRESS22 = 0x22
class I2CIO:
    def __init__(self, address, i2c, pin , pintype):
        if pin == 4:
            pin = 7
        elif pin == 5:
            pin = 6
        elif pin == 6:
            pin = 5
        elif pin == 7:
            pin = 4
        reg_addr = 0x00 + (pin // 8)  # TCA6424A_RA_OUTPUT0 + (pin / 8)
        bit_num = pin % 8
        self.address = address
        self.reg_addr = reg_addr
        self.bit_num = bit_num
        self.i2c = i2c
        self.write_setup(pintype)
        if pintype==0:
            self.off()
    # setup pin
    def write_setup(self, pintype):
        b = i2c.readfrom_mem(self.address, self.reg_addr+12, 1)[0]
        if pintype != 0:
            b |= (1 << self.bit_num)
        else:
            b &= ~(1 << self.bit_num)
        i2c.writeto_mem(self.address, self.reg_addr+12, bytes([b]))
        return b
    def on(self):
        self.write_output(1)
    def off(self):
        self.write_output(0)
    def write_output(self, value):
        b = i2c.readfrom_mem(self.address, self.reg_addr+4, 1)[0]
        if value != 0:
        else:
        i2c.writeto_mem(self.address, self.reg_addr+4, bytes([b]))
        return b
DO_0 = Pin('PI6', Pin.OUT_PP, Pin.PULL_NONE)
DO_1 = Pin('PH9', Pin.OUT_PP, Pin.PULL_NONE)
DO_2 = Pin('PJ9', Pin.OUT_PP, Pin.PULL_NONE)
DO_3 = Pin('PE2', Pin.OUT_PP, Pin.PULL_NONE)
DO_4 = Pin('PI3', Pin.OUT_PP, Pin.PULL_NONE)
DO_5 = Pin('PI2', Pin.OUT_PP, Pin.PULL_NONE)
DO_6 = Pin('PD3', Pin.OUT_PP, Pin.PULL_NONE)
DO_7 = Pin('PA14', Pin.OUT_PP, Pin.PULL_NONE)
ProCH00 = I2CIO(I2C_ADDRESS22, i2c, 0,0)
ProCH01 = I2CIO(I2C_ADDRESS22, i2c, 1,0)
ProCH02 = I2CIO(I2C_ADDRESS22, i2c, 2,0)
ProCH03 = I2CIO(I2C_ADDRESS22, i2c, 3,0)
ProCH04 = I2CIO(I2C_ADDRESS22, i2c, 4,0)
ProCH05 = I2CIO(I2C_ADDRESS22, i2c, 5,0)
ProCH06 = I2CIO(I2C_ADDRESS22, i2c, 6,0)
ProCH07 = I2CIO(I2C_ADDRESS22, i2c, 7,0)
ProCH08 = I2CIO(I2C_ADDRESS22, i2c, 8,0)
ProCH09 = I2CIO(I2C_ADDRESS22, i2c, 9,0)
ProCH010 = I2CIO(I2C_ADDRESS22, i2c, 10,0)
ProCH011 = I2CIO(I2C_ADDRESS22, i2c, 11,0)
print ("____ SETUP complete_____")
while True:
  pausetime = 200
  DO_0.on()
  pyb.delay(pausetime)
  DO_0.off()
  DO_1.on()
  DO_1.off()
  DO_2.on()
  DO_2.off()
  DO_3.on()
  DO_3.off()
  DO_4.on()
  DO_4.off()
  DO_5.on()
  DO_5.off()
  DO_6.on()
  DO_6.off()
  DO_7.on()
  DO_7.off()
  ProCH00.on()
  ProCH00.off()
  ProCH01.on()
  ProCH01.off()
  ProCH02.on()
  ProCH02.off()
  ProCH03.on()
  ProCH03.off()
  ProCH04.on()
  ProCH04.off()
  ProCH05.on()
  ProCH05.off()
  ProCH06.on()
  ProCH06.off()
  ProCH07.on()
  ProCH07.off()
  ProCH08.on()
  ProCH08.off()
  ProCH09.on()
  ProCH09.off()
  ProCH010.on()
  ProCH010.off()
  ProCH011.on()
  ProCH011.off()
