Portenta Ultrasonic RangeFinder HC-SR04
Has anyone got a RangeFinder working with the Portenta?
Here is my code, but I just get zero's. I am testing if a 1 Kohm resistor is needed between the Echo Pin and the Portenta.
int myTriggerPin = 7;
int myEchoPin = 6;
unsigned long myDuration;
  pinMode(myTriggerPin, OUTPUT);
  pinMode(myEchoPin, INPUT_PULLDOWN);
  digitalWrite(myTriggerPin, LOW);
  delayMicroseconds(10);
  digitalWrite(myTriggerPin, HIGH);
  myDuration = pulseIn(myEchoPin, HIGH, 40000UL);
  Serial.println(myDuration);
  delay(10);
I filed an issue about pulseIn() on the mbed github, but Arduino proved pulseIn works. I expect I am messing something up.
Is the Portenta a 5V board? The HC-SR04 operating voltage is 5V.
Nope, but it has a 5V output pin. I have also tried a 1 k ohm resistor at the echo pin, but still get zeros. The rangeFinders work fine with other boards. (Yes, I am capable of really stupid errors, that is why I repeat things from scratch many times. )
Yes the 5V pin should be used thanks @groundFungus. Still nothing working with the Portenta and this range finder. Anyone else have any suggestions.
Wondering if other pins would be better to try.
I tried it again and this code worked fine.
// Note: VCC on RangeFinder must go to +5V on Portenta
//         GND on rangefinder goes to GND on Portenta
int myTriggerPin = D6;  // Trigger on RangeFinder
int myEchoPin = D7;     // Echo on Rangefinder
  Serial.println("Duration us: "+ String(myDuration));
  delay(200);
  if (myDuration > 2000    ){       // raw data from 200 to 16000
                                        // where  2000 raw = ~35cm,  4000 raw = ~80cm
       digitalWrite(LEDB, LOW);    // LEDB Blue LED on if far
        digitalWrite(LEDB, HIGH);   // LEDB Blue LED off if close or nothing
Sorry for the question. Did you use the 5V pin finally or is there any alternative? Faced with Vortex stuff(here is an article)
Thanks in advance
