Hello, I don't understand this:
uint8_t val = 194;
why is this working:
PORTF |= val & 0xf0;
but not that:
PORTF |= val & 128;
PORTF |= val & 64;
PORTF |= val & 32;
PORTF |= val & 16;
I've read some issues with the fuses and the PORTF, but I don't thinks thats the problem.
By the way, the lower Bits of PORTF are working fine:
PORTF |= val & 8;
PORTF |= val & 4;
PORTF |= val & 2;
PORTF |= val & 1;
But I want to set single bits for the higher bits also, so it would be nice if anyone can give me a hint.
Which Arduino?
Convert each of those hex and decimal values to binary. (Use the Windows calculator in programmer mode.) What is different?
PORTF write issue (Arduino ProMicro 32u4)
I have no windows.
I've tested it with Java and a value of 170: 10101010
Result: 160, 10100000
Seems ok. But it's not working with a 32u4 and PORTF.
westfw
#4
Should work. Can you post a complete not-working program?
system
#5
What is the value of PORTF to start with? Maybe you only need:
PORTF = val & 128;
If you like to make people trying to help look stupid by editing your original post then you will not get much more help.
