Porting a straight C program to run on Arduino?
I located a set of source code for the old text based star trek game. I was thinking I could possibly port it over to run using the serial monitor. Problem is.. All this stuff is written in straight c and I can't get it to accept my glue code.
To start off I wrote two files.
gloabals.h
#ifndef globals_h
#define globals_h
#include "Arduino.h"
extern "C" void randomize(void);
extern "C" int getch(void);
//extern "C" int max(int a, int b);
//extern "C" int min(int a, int b);
#endif
And gloabls.cpp
#include "globals.h"
void randomize(void) {
  //srand((int)time(NULL));
int getch(void) {
  while(!Serial.available());
  return (int)Serial.read();
And the compiler kicks out this..
globals.h:7: error: expected identifier or '(' before string constant
globals.h:9: error: expected identifier or '(' before string constant
Along with lots of other things, but this is the start and I need to at least get this first function to work.
Anyone have experience in soething like this? 'Cause I don't have a lot in this area.
Thanks!
-jim lee
Try it without the includes.
Arduino hides a lot of the standard C from the user, including libraries like stdio.h.
You can probably copy the logic of the original program and write functions to replace the I/O.
Since you want to start with getch(), look at this.
AFAIK the compiler compiles files *.c as C and *.cpp as C++. The extern "C" hack is only required for C declarations compiled as C++, i.e. with header files #included in *.cpp files.
The compiler generates different compiled identifiier names for C (underscore) and C++ (mangled names), so that a function declared as C has to be made known to C++ callers as extern "C" in its header file, else the linker cannot find a function with the mangled name.
If you want to use C standard libraries, these will conflict with C++ standard libraries. Else you can compile all C code as C++, with (hopefully) few adaptations.
