Porting Arduino code on ESP8266 generates an exception
This is part of the code I am trying to port on an ESP8266:
#include <Arduino.h>
#define BUFFER_SIZE   256   ///< Set the size of serial buffer
#define BAUDRATE      9600  ///< Set the Baudrate of easycomm 3 protocol
    Serial.begin(BAUDRATE);
    char buffer[BUFFER_SIZE];
    char incomingByte;
    char *Data = buffer;
    char *rawData;
    static uint16_t BufferCnt = 0;
    char data[100];
    // Read from serial
    while (Serial.available() > 0) {
        ESP.wdtFeed();
        incomingByte = Serial.read();
        // Read new data
        if (incomingByte == '\n' || incomingByte == '\r') {
            buffer[BufferCnt] = 0;
            if (buffer[0] == 'A' && buffer[1] == 'Z') {
                if (buffer[2] == ' ' && buffer[3] == 'E' && buffer[4] == 'L') {
                    Serial.println("Dummy");
                    rawData = strtok_r(Data, " ", &Data);
                    strncpy(data, rawData + 2, 10);
                    if (isNumber(data)) {
                        Serial.print("AZ: ");
                        Serial.println(atof(data));
                    if (rawData[0] == 'E' && rawData[1] == 'L') {
                            Serial.print("EL: ");
            // Reset the buffer an clean the serial buffer
            BufferCnt = 0;
            Serial.flush();
            // Fill the buffer with incoming data
            buffer[BufferCnt] = incomingByte;
            BufferCnt++;
bool isNumber(char *input) {
    for (uint16_t i = 0; input[i] != '\0'; i++) {
        if (isalpha(input[i]))
            return false;
    return true;
When I type AZ12 EL23 in the serial console, I got:
AZ: 12
EL: 34
But when I type AZ12 only (the ELxx command should be optional), I got "AZ: 12" on an Arduino Uno but the ESP8266 generates an exception:
Exception (28):
epc1=0x40201195 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
Would you please help me to sort this out?
A search for "Exception (28): esp8266" yields this page:
https://www.esp8266.com/viewtopic.php?t=4665
Among others.
Thanks for pointing me on the right direction.
This solved my issue:
                        if (rawData = strtok_r(Data, " ", &Data)) {
                                    control_el.setpoint = atof(data);
Glad to hear that you got it fixed.
If your question has been answered to your satisfaction, please mark the thread as solved so that other members that wish to help will not waste their time opening the thread only to find that you no longer require assistance.
