Porting Arduino driver to PC
The link below is a NFC driver for Arduino.
Is it possible to port this Arduino driver code to a PC platform and replace the UART function calls to that of a PC. Can that be done with minimal change? What are the things to consider?
How would you attach the shield to the PC?
That is not a driver. To use its own words, it is a "NFC library for Arduino"
It is written to work with an Arduino with specific additional hardware that cannot be connected directly to a PC.
You can, of course, connect the Arduino to a PC and use the Arduino to send data from the NFC device to the PC.
...R
PaulS:
The shield has UART interface. I can use a FTDI USB-to-UART converter so that PC can talk to the shield through UART.
Robin2:
...R
What is specific to Arduino is the communication interface(I2C, SPI, UART) that the NFC library uses. The library itself looks independent of the underlying hardware. This is why I was wondering if one can use it on the PC but modify the communication interface portion. Did I miss out anything?
lightaiyee:
Your original post did not have the clarifications in Replies 3 and 4
Now that I understand what you want to do I can say it is well beyond my pay grade.
...R
