I don't have a list of step by step instructions on how to make the necessary changes, but I did take notes are I was figuring out how to get all of this to work for the Tau:
Must edit:
C:\Users\Shawn\AppData\Local\Arduino15\packages\tau\hardware\samd\1.6.5\boards.txt
To have correct processor flag.
Makefile for project also contains this reference:
Rabid Prototypes Tau (PID == 0x004D)
CFLAGS_EXTRA?=-D__SAMD21E17A__ -DUSB_PID_HIGH=0x00 -DUSB_PID_LOW=0x4D -DUSB_VID_LOW=0x41 -DUSB_VID_HIGH=0x23
Left the PID and VID alone so it identifies as a Zero. Changed the processor flag.
Changed device selection in Atmel Studio to SAMD21E17A as well.
BootloaderSam21x18.ld has the following lines:
/* Linker script to configure memory regions.
- Need modifying for a specific board.
- FLASH.ORIGIN: starting address of flash
- FLASH.LENGTH: length of flash
- RAM.ORIGIN: starting address of RAM bank 0
- RAM.LENGTH: length of RAM bank 0
MEMORY
FLASH (rx) : ORIGIN = 0x00000000, LENGTH = 0x2000 / First 8KB used by bootloader /
RAM (rwx) : ORIGIN = 0x20000000, LENGTH = 0x00008000-0x0004 / 4 bytes used by bootloader to keep data between resets */
Does this need to be altered?
0x00008000 = 32K. That is the length of the ram?
Minus the 4 bytes used by the bootloader = length of usable ram?
So I guess I should change that to 4000 for the SAMD21E17A since it only has 16K of ram.
I changed the filename to SAM21x17 then realized it is probably referenced somewhere.
Turns out Makefile references it:
$(ELF): Makefile $(BUILD_PATH) $(OBJECTS)
@echo ----------------------------------------------------------
@echo Creating ELF binary
"$(CC)" -L. -L$(BUILD_PATH) $(LDFLAGS) -Os -Wl,--gc-sections -save-temps -Tbootloader_samd21x17.ld -Wl,-Map,"$(BUILD_PATH)/$(NAME).map" -o "$(BUILD_PATH)/$(ELF)" -Wl,--start-group $(OBJECTS) -lm -Wl,--end-group
"$(NM)" "$(BUILD_PATH)/$(ELF)" >"$(BUILD_PATH)/$(NAME)_symbols.txt"
"$(SIZE)" --format=sysv -t -x $(BUILD_PATH)/$(ELF)
<sam.h> not found!
Found this on the web:
sam.h is not included.
go to: properties -> toolchain -> ARM/GNU C Compiler -> Directories and add
include path:
C:\Program Files\Atmel\Atmel Toolchain\ARM
GCC\Native\4.8.1443\CMSIS_Atmel\Device\ATMEL
C:\Users\Shawn\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel\Device\ATMEL
I have no idea how to make this a friendly path that would work regardless of the user that installed it, but that’s where sam.h is.
But I notice there is a checkbox for “include device support header path”. What is that?
Well, I think maybe that means to include the paths I specify in the box.
And when I pasted the address above into the dialog that came up and left “relative path” checked it spit this out in the path dialog:
../../../../../../../arduino/tools/CMSIS/4.0.0-atmel/Device/ATMEL
And when I click that “relative path” is now checked, so I guess if I’d entered that in the first place I would have had to check that box.
And I guess that’s 7 directories up from where my project is? But that can’t be Tau, so it must be Tau/Release? I see a make file in there. So I guess maybe that’s it.
I also had to include this directory:
C:\Users\Shawn\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel\CMSIS\Include
Could not successfully build release after adding those directories due to missing USB VID PID defines. These are in the makefile provided... but it seems release generates a new makefile and it doesn’t have these? And the provided makefile does, and has those directories defined in it for the includes?
All I know is a debug build compiles, release does not.
But debug also only generates an .ELF file, no BIN which is needed for Arduino to burn bootloader. Why?
I think I see the problem. Release build config didn’t have “use external makefle” checked under build?
I’m not sure what I wrote that for, but it turns out that if I click “build samd21” and not “build project” then it creates .HEX and .BIN files in addition to the .ELF
In:
C:\Users\Shawn\AppData\Local\Arduino15\packages\rabid prototypes\hardware\samd\1.6.5\variants\tau\linker_scripts\gcc
Have to modify two linker scripts for compilation.
MEMORY
FLASH (rx) : ORIGIN = 0x00000000+0x2000, LENGTH = 0x00040000-0x2000 /* First 8KB used by bootloader */
Here, LENGTH = 0x00008000 must be changed to LENGTH = 0x00004000 because tau has half the ram.
And 0x00040000 for the flash length equals 262,144 and the Tau has half the flash, so that also has to be reduced.
The last piece of a puzzle is that the default BOSSA tool which uploads to the board does not provide support for the SAMD21E17:
BOSSA/src/Devices.h at arduino · shumatech/BOSSA · GitHub
Unless you tick a little box in the IDE that tells it to provide verbose output during UPLOAD (not compile, they are two separate options!) the only error you will see when BOSSA does not recognize the processor is “no device found on COM [whatever]”, which would lead you to believe there is a problem with your board’s hardware instead of a problem with the IDE’s tools.
There is a version of BOSSA here which has been recompiled to include support for all the SAMD, SAMC, and SAML chips:
GitHub - mattairtech/BOSSA: BOSSA is a flash programming utility for Atmel's SAM family of flash-based ARM microcontrollers. The motivation behind BOSSA is to create a simple, easy-to-use, open source utility to replace Atmel's SAM-BA software. BOSSA is an acronym for Basic Open Source SAM-BA Application to reflect that goal.
Actual compiled version can be found hre:
GitHub - mattairtech/ArduinoCore-samd: This is a fork from arduino/ArduinoCore-samd on GitHub. This will be used to maintain Arduino support for SAM D|L|C (M0+ and M4F) boards including the MattairTech Xeno Mini and the MT-D21E (see https://www.mattairtech.com/). It adds support for new devices like the D51, L21, C21, and D11. It also adds new clock sources, like a high speed crystal or internal oscillator.
Scroll down and there are links to compiled versions near the bottom. Alternatively you can use the boards manager to install the mattairtech board files which have a compiled BOSSA in the tools folder for that variant.
