Porting some basic code over to arduino with GOTO command
I have some basic code written in PDS and would like to see about porting it over into arduino, But I have a couple of goto statmeants and I've read that the GOTO command is discouraged in C
Which would be the best way to approach this in replacing goto within the loop
here is the basic code
MAIN:
 '##### CHECKS IF THE E-STOP OR FAIL SAFE IS ACTIVATED ####
 If GATE_LIMIT = 0 Or MAX_HIEGHT = 0 Then
 MOTOR_ENABLE = 0:DUTY=0:LIFT_DWN_COIL = 0:LIFT_UP_COIL=0:UP_FLAG = 0
 EndIf
'##### WAITS FOR THE LIFT UP SWITCH TO BE PRESSED ########
 If LIFT_UP = 0 Then
 UP_FLAG = 1:UP_SEC = 20:MOTOR_ENABLE=1:LIFT_UP_COIL = 1
DUTY_SLOW = ERead SLOWDOWN_DUTY
DUTY = DUTY_SLOW
   RSOut "LIFTING PLATFORM",13
 GoTo LIFTING_UP
 EndIf
'##### WAITS FOR THE LIFT DOWN SWITCH TO BE PRESSED ########
'# TURNS THE PUMP ON FOR .25 SECONDS TO PREVENT DROP ON LOWERING ##
 If LIFT_DWN = 0 Then
  If GATE_LIMIT = 0 Then
  RSOut "GATE OPEN, CLOSE GATE",13,10
  GoTo MAIN
  Else
 SEC_DWN = ERead DWN_SEC_TEMP
 DUTY = 200
 delay2 = 85
 GoSub DELAYR
 DWN_FLAG = 1:MOTOR_ENABLE=0:LIFT_UP_COIL = 0
 LIFT_DWN_COIL = 1:RSOut "gate",Dec GATE_LIMIT
 GoTo LIFTING_DOWN
 EndIf
 EndIf
 GoTo MAIN
it jumpd here
 LIFTING_UP:
'##### CHECKING THE STATE OF THE LIMIT SWITCHES ####
    MOTOR_ENABLE = 0:DUTY=0:LIFT_DWN_COIL = 0:LIFT_UP_COIL=0:UP_FLAG = 0:DWN_FLAG = 0
    delay2 = 100
  GoSub DELAYR
  GoTo MAIN
  EndIf
'##### FAIL SAFE LIMIT SWITCH #########
 If MAX_HIEGHT = 0 Then
   RSOut "FAIL SAFE LIMIT SWITCH ACTIVATED",13
    delay2 = 100
  GoSub DELAYR
  GoTo MAIN
  EndIf
     DUTY_MAX1 = ERead DUTY_TEMP
     DelayUS 10
DUTY_MAX = DUTY_MAX1
DUTY_SLOW1=  DUTY_SLOW
'#### SETS THE LIFT SPEED #################
  If UP_FLAG = 1 And HEIGHT_REACHED = 1 Then
  Inc DUTY
  DelayUS 500
  If DUTY > DUTY_MAX Then  'SETS MAX LIFT SPEED
  DUTY = DUTY_MAX
  EndIf
  EndIf
'##### CHECKING THE STATE OF THE LIMIT SWITCHES AND PRE-SLOW DOWN ACTIVATION ####
  If UP_FLAG = 1 And HEIGHT_REACHED = 0   Then
  Dec DUTY
  DelayMS 15
  If DUTY < DUTY_SLOW1  Then
  DUTY = DUTY_SLOW1
   RSOut "STAGE 1 COMPLETE SLOWING DOWN",13
  EndIf
  EndIf
  If  UP_FLAG = 1 And HEIGHT_REACHED = 0  And DUTY < DUTY_SLOW1 +5 Then
  LIFT_UP_COIL = 0:UP_FLAG = 0
  MOTOR_ENABLE=0
   RSOut "LIFTING COMPLETED",Dec DUTY,13
  GoTo MAIN
  EndIf
  CCP1CON.4 = DUTY.0          ' Store duty to registers as
  CCP1CON.5 = DUTY.1          ' a 10-bit word
  CCPR1L = DUTY >> 2
   '##### USED FOR DEBUGING ONLY #############
  GoTo LIFTING_UP
I should be able to port all of it or most of it over to adruino has I understand most of it but just unsure about the goto part. I've got the basic part working waiting for the button presses but just turn led on/off with rather than the goto at the moment
There is a GOTO command in C/C++
It is frowned on because it can cause unexpected consequences, it's a bit like "beam me up Scotty" in reverse - maybe the place you GOTO is full of man-eating tigers.
The best thing would be to understand what the existing code is intended to achieve and then write some Arduino code to achieve the same thing.
I can't help feeling that if the existing code uses GOTO it probably has many other deficiencies also.
...R
It looks to me like they're using it to simulate a function or subroutine call... In which case it's easy to work around
This is closer to what you want (it won't compile yet, but it is getting there):
void LIFTING_UP ()
  while (true)
    // ##### CHECKING THE STATE OF THE LIMIT SWITCHES ####
    if (GATE_LIMIT == 0) {
      RSOut "GATE OPEN, CLOSE GATE", 13, 10;
      MOTOR_ENABLE = 0;
      DUTY = 0;
      LIFT_DWN_COIL = 0;
      LIFT_UP_COIL = 0;
      UP_FLAG = 0;
      DWN_FLAG = 0;
      delay2 = 100;
      DELAYR ();
      return;
    // ##### FAIL SAFE LIMIT SWITCH #########
    if (MAX_HIEGHT == 0) {
      RSOut "FAIL SAFE LIMIT SWITCH ACTIVATED", 13;
      MOTOR_ENABLE = 0;
      DUTY = 0;
      LIFT_DWN_COIL = 0;
      LIFT_UP_COIL = 0
      UP_FLAG = 0;
      delay2 = 100
      DELAYR ();
      return;
    DUTY_MAX1 = ERead DUTY_TEMP;
    DUTY_SLOW = ERead SLOWDOWN_DUTY;
    DelayUS 10;
    DUTY_MAX = DUTY_MAX1;
    DUTY_SLOW1 =  DUTY_SLOW
    // #### SETS THE LIFT SPEED #################
    if (UP_FLAG == 1 && HEIGHT_REACHED == 1) {
      DUTY++;
      DelayUS 500;
      if (DUTY > DUTY_MAX) {  // SETS MAX LIFT SPEED;
        DUTY = DUTY_MAX;
    // ##### CHECKING THE STATE OF THE LIMIT SWITCHES AND PRE-SLOW DOWN ACTIVATION ####
    if (UP_FLAG == 1 && HEIGHT_REACHED == 0)   {
      DUTY--;
      DelayMS 15;
      if (DUTY < DUTY_SLOW1)  {
        DUTY = DUTY_SLOW1;
        RSOut "STAGE 1 COMPLETE SLOWING DOWN", 13
    if  (UP_FLAG == 1 && HEIGHT_REACHED == 0  && DUTY < DUTY_SLOW1 + 5) {
      LIFT_UP_COIL = 0;
      UP_FLAG = 0;
      MOTOR_ENABLE = 0;
      RSOut "LIFTING COMPLETED", Dec DUTY, 13;
      return;
    CCP1CON.4 = DUTY.0  ;        //  Store duty to registers as
    CCP1CON.5 = DUTY.1  ;       //  a 10-bit word
    CCPR1L = DUTY >> 2;
    // ##### USED FOR DEBUGING ONLY #############
  }  // end of while
} // end of LIFTING_UP
It looks like LIFTING_UP could be a function (which you call). When you want to return to MAIN just do a "return" which exits the function. You need to put semicolons at the end of lines (except "if") and put function arguments into brackets.
In C/C++ you generally don't use all caps for variables, for neatness you might want to avoid doing that.
Thanks Nick I'm now making progress, I now have it working but there is still lots to do which I'm going to complete a stage at a time, Lift up working now going to add lift down, The limit switch now jumps to locked where I need to add a bit more code to continue where it left off when normal state is resumed which is the next part.
Here is the code I have so far will need tidying up
const int Gate_limitpin = 11;
const int Max_hieghtlimitpin = 12;
const int Motor_enable= 3;
const int upbuttonPin = 2;
const int LIFT_DWN_COIL = 4;
const int LIFT_UP_COIL= 5;
const int HEIGHT_REACHED = 6;
boolean UP_FLAG = false;
boolean DWN_FLAG = false;
int Duty = 100;
int Duty_SLOW1 = 90;
int Duty_MAX = 150;
  pinMode(upbuttonPin, INPUT);
 digitalWrite(upbuttonPin,HIGH);
 pinMode(HEIGHT_REACHED,OUTPUT);
 pinMode( Gate_limitpin, INPUT);
  digitalWrite(Gate_limitpin,HIGH);
  pinMode(Max_hieghtlimitpin, INPUT);
  digitalWrite(Max_hieghtlimitpin, HIGH);
  pinMode(Motor_enable, OUTPUT);
  pinMode(HEIGHT_REACHED,INPUT);
  digitalWrite(HEIGHT_REACHED,HIGH);
   if ((digitalRead(Gate_limitpin) == LOW) || (digitalRead(Max_hieghtlimitpin) ==LOW)){
 digitalWrite(Motor_enable, LOW);
  Serial.println("Gate open or max hieght limit switch active");
  LOCKED ();
 if (digitalRead(upbuttonPin) == LOW){
     digitalWrite(Motor_enable, HIGH);
     UP_FLAG = 1;
     Serial.println("lifting");
     Serial.println(UP_FLAG);
     LIFTING_UP ();
void LIFTING_UP ()
  while (true)
     Serial.print("Duty =");
    Serial.println(Duty);
    if (digitalRead(Gate_limitpin) == LOW)
      Serial.println( "GATE OPEN, CLOSE GATE");
      digitalWrite(LIFT_DWN_COIL, LOW);
      digitalWrite(LIFT_UP_COIL, LOW);
      digitalWrite(UP_FLAG, LOW);
      digitalWrite(DWN_FLAG, LOW);
      return;
    if (digitalRead(Max_hieghtlimitpin) == LOW) {
      Serial.println( "FAIL SAFE LIMIT SWITCH ACTIVATED");
      return;
    Duty_MAX1 = ERead Duty_TEMP;
    Duty_SLOW = ERead SLOWDOWN_Duty;
    DelayUS 10;
    Duty_MAX = Duty_MAX1;
    Duty_SLOW1 =  Duty_SLOW
    if (UP_FLAG == 1 && (digitalRead(HEIGHT_REACHED) == HIGH)) {
      Duty++;
      if (Duty > Duty_MAX) {  // SETS MAX LIFT SPEED;
        Duty = Duty_MAX;
    if (UP_FLAG == 1 && (digitalRead(HEIGHT_REACHED) == LOW))   {
      Duty--;
      delay(100);
      if (Duty < Duty_SLOW1)  {
        Duty = Duty_SLOW1;
        Serial.println( "STAGE 1 COMPLETE SLOWING DOWN");
    if  (UP_FLAG == 1 && (digitalRead(HEIGHT_REACHED) ==LOW  && Duty < Duty_SLOW1 + 5)) {
      Serial.println( "LIFTING COMPLETED");
      return;
    }  // end of while
void LOCKED ()
  while (true)
    Serial.println("LIMTI SWITCH ATCIVE");
  return;
I've nearly got it all working, Just a little problem with part of my code, When I push the lift down button it set the SEC_DWN timer to 15 seconds and jumps to the LIFTING_DOWN function and it counts down to zero then back to the main loop, But the trouble is because I'm using the a delay(1000); there is a 1.5 seconds delay before it jumps out of the LIFTING_DOWN. I need this to be instasnt I know this delay may be caused by the delay(1000), is the a more elegant way without using delay I've seen something about using mills but for counting up rather than down I think
Code below using delay
void  LIFTING_DOWN ()
  while (true)
    Serial.println(SEC_DWN);
    SEC_DWN --;
    //'######## CHECKS IF THE E-STOP HAS BEEN PUSHED ###########
    if ((DWN_FLAG = 1) && (digitalRead(Gate_limitpin) == LOW)) {
      DWN_FLAG =  true;
      while (digitalRead(Gate_limitpin) == LOW) {
        Serial.println("GATE OPEN, CLOSE GATE");
      return;
    //####### COUNTS DOWN THE TIME AND TURNS OFF THE DOWN REALY ############
    if ((DWN_FLAG == 1) && (SEC_DWN < 1 )) {
      Serial.print("LOWERING COMPLETED");
      if (SEC_DWN < 0)
        SEC_DWN = 0;
      return;
Ah yes. Gammon Forum : Electronics : Microprocessors : How to do multiple things at once ... like cook bacon and eggs
Wow Nick Thanks I shall be looking at that looks a lot better way of doing it than mine
Good site you have there I sure will be spending sometime on there
thanks
Steve
Saint Nick.
