Hello! I have a 7 digit seven segment LED display from a DVD player. It has a TM1623 LED controller. I found a library and an example code for a similar led controller. It called TM1628. It has a different pinout. When I connected the led controller to my Arduino UNO R3, I uploaded the code. It showed me meaningless characters. How can I port the TM1628`s library to TM1623? Please help! Thanks!
Pictures:
You need to change the library to use the new device's pins in the same order.
It should be relatively simple to light up one segment, and verify that the correct segment lights up. Correct any pin arrangements that do not result in the correct segment lighting up. When all segments light up properly, the rest of the library should just work.
