position of * when declaring pointers in C
I'm learning about passing pointers as arguments to functions.
I'm wondering if there is a difference between the following notation?
void function(char* name)
void function(char *name)
The code as I expect using both notations but I'm wondering if people use the notation interchangeably?
Thanks
No difference at all, but remember that the * binds to the variable, so if you're defining something like int* var1, var2;
"var1" is a pointer to int, but var2 is just a plain int.
c/c++ compilers pay almost no attention to "white space" in the source code, so those two statements are functionally identical.
These two statements are also functionally identical:
char *s = "12345";
char
s
"12345"
Regards,
Ray L.
So, it is better to write it with variable name.
int *var1, var2;
. . . or is it better to define each variable with its own type? (my preference)
many thanks
