I modified this sketch from Brainy-Bits to use with my Adafruit V2 shield and the home function works up until the limit switch is hit. Then when I enter new positions in the serial monitor the monitor says the stepper moved and in fact it does not. I think there is an issue in my void loop or at the end of setup, but I can’t find it.
any eyes on and advice is appreciated.
/* Motor Homing code using AccelStepper and the Serial Monitor
Created by Yvan / https://Brainy-Bits.com
This code is in the public domain...
#include <AccelStepper.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
Adafruit_MotorShield AFMSmid(0x61); // I2C address of MEGA shield.
Adafruit_StepperMotor *mystepper1 = AFMSmid.getStepper(200, 1); // 200step 1.8degree Motor on port #1 (M1 and M2).
// Define the Pins used
#define home_switch 18 // Pin 18 connected to Home Switch (MicroSwitch)
// Stepper Travel Variables
long TravelX; // Used to store the X value entered in the Serial Monitor
int move_finished = 1; // Used to check if move is completed
long initial_homing = -1; // Used to Home Stepper at startup
void forwardstep1() {
mystepper1->onestep(FORWARD, SINGLE);
void backwardstep1() {
mystepper1->onestep(BACKWARD, SINGLE);
AccelStepper Astepper1(forwardstep1, backwardstep1); // use functions to step
Serial.begin(9600); // Start the Serial monitor with speed of 9600 Bauds
AFMSmid.begin(); // create with the default frequency 1.6KHz
pinMode(home_switch, INPUT_PULLUP);
delay(5); // Wait for EasyDriver wake up
// Set Max Speed and Acceleration of each Steppers at startup for homing
Astepper1.setMaxSpeed(100.0); // Set Max Speed of Stepper (Slower to get better accuracy)
Astepper1.setAcceleration(100.0); // Set Acceleration of Stepper
// Start Homing procedure of Stepper Motor at startup
Serial.print("Stepper is Homing . . . . . . . . . . . ");
while (digitalRead(home_switch)) { // Make the Stepper move CCW until the switch is activated
Astepper1.moveTo(initial_homing); // Set the position to move to
initial_homing--; // Decrease by 1 for next move if needed
Astepper1.run(); // Start moving the stepper
delay(5);
Astepper1.setCurrentPosition(0); // Set the current position as zero for now
initial_homing = 1;
while (!digitalRead(home_switch)) { // Make the Stepper move CW until the switch is deactivated
Astepper1.run();
initial_homing++;
delay(5);
Serial.println("Homing Completed");
Serial.println("");
Astepper1.setMaxSpeed(1000.0); // Set Max Speed of Stepper (Faster for regular movements)
Astepper1.setAcceleration(1000.0); // Set Acceleration of Stepper
// Print out Instructions on the Serial Monitor at Start
Serial.println("Enter Travel distance (Positive for CW / Negative for CCW and Zero for back to Home): ");
while (Serial.available() > 0) { // Check if values are available in the Serial Buffer
move_finished = 0; // Set variable for checking move of the Stepper
TravelX = Serial.parseInt(); // Put numeric value from buffer in TravelX variable
if (TravelX < 0 || TravelX > 1350) { // Make sure the position entered is not beyond the HOME or MAX position
Serial.println("");
Serial.println("Please enter a value greater than zero and smaller or equal to 1350.....");
Serial.println("");
Serial.print("Moving stepper into position: ");
Serial.println(TravelX);
Astepper1.moveTo(TravelX); // Set new moveto position of Stepper
delay(1000); // Wait 1 seconds before moving the Stepper
if (TravelX >= 0 && TravelX <= 1350) {
// Check if the Stepper has reached desired position
if ((Astepper1.distanceToGo() != 0)) {
Astepper1.run(); // Move Stepper into position
// If move is completed display message on Serial Monitor
if ((move_finished == 0) && (Astepper1.distanceToGo() == 0)) {
Serial.println("COMPLETED!");
Serial.println("");
move_finished = 1; // Reset move variable
If you see the message from line 66 Serial.println("Homing Completed"); then I don't think the problem has anything to do with homing.
The code for receiving data is not at all robust. Just because Serial.parseInt() is satisfied once does not mean that the input buffer is empty and the next time around loop() there may be another character that is not sufficient to satisfy parseInt(). Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
Temporarily take out the entire WHILE clause and just give TravelX the value 200 and see what happens.
AROTTER2:
I removed the "while" in the loop and doing so the serial monitor reads this.
Then when I enter a value nothing happens.
You need to post the latest version of your program so we can see exactly what you did.
In my Reply #1 I intended you to create a system that does not ask for any input and, instead, uses a fixed value for TravelX just to see if the stepper code is working properly.
Ok, with this code it now Stops at limit switch and then moves 200 like I belive you asked.
thank you again
#define home_switch 18 // Pin 9 connected to Home Switch (MicroSwitch)
mystepper1->onestep(FORWARD, DOUBLE);
mystepper1->onestep(BACKWARD, DOUBLE);
delay(5);
initial_homing = 1;
Astepper1.run();
initial_homing++;
delay(5);
mystepper1->release(); //Release steper to save on heat! Using <Adafruit_MotorShield.h>
Serial.println("");
Astepper1.setMaxSpeed(600.0); // Set Max Speed of Stepper (Faster for regular movements)
Astepper1.setAcceleration(600.0); // Set Acceleration of Stepper
/* while (Serial.available() > 0) { // Check if values are available in the Serial Buffer
Serial.println("");
Serial.println("");
Astepper1.moveTo(200); // Set new moveto position of Stepper
// delay(1000); // Wait 1 seconds before moving the Stepper
Serial.println("");
OK. That’s progress. But I had intended that you would do this
TravelX = 200;
Astepper1.run();
because that lays the groundwork for adding in code that gets the value for TravelX from Serial
Now add in some code to receive the serial data - if you are just sending data from the Serial Monitor then the code in the 2nd example in Serial Input Basics will be sufficient, although the 3rd example would be more reliable if you are prepared to take the trouble to enter <200> rather than just 200.
When you have that done all that should happen is whenever you enter data in the Serial Monitor it prints the message “This just in NNN” where NNN is the number you entered. And when that is working we can go another step.
Keep the code from my example in functions just like I have posted it.
ok, it Homes, steps 200 and then displays “This just in NNN” with whatever I enter into the serial monitor .
const byte numChars = 32;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
delay(5);
Astepper1.setAcceleration(50.0); // Set Acceleration of Stepper
delay(5);
initial_homing = 1;
Astepper1.run();
initial_homing++;
delay(5);
Serial.println("");
Serial.println("");
Serial.println("");
TravelX = 200;
Astepper1.run();
recvWithEndMarker();
showNewData();
void recvWithEndMarker() {
static byte ndx = 0;
char endMarker = '\n';
char rc;
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
void showNewData() {
if (newData == true) {
Serial.print("This just in ... ");
Serial.println(receivedChars);
newData = false;
Serial.println("");
Before we get too far, I wanted to clarify that eventually I am looking to replace the “TravelX” with serial input from a light sensor to use to adjust position of the stepper.
Thank you again!
delay(5);
delay(5);
initial_homing = 1;
Astepper1.run();
initial_homing++;
delay(5);
Serial.println("");
// TravelX = 200;
Astepper1.run();
showNewData();
char rc;
rc = Serial.read();
ndx++;
ndx = numChars - 1;
else {
ndx = 0;
newData = true;
void parseData() {
TravelX = atol(receivedChars); // note that it is ATOL(
newData = false;
You are missing a bit in loop(). It should be like this
// TravelX = 200;
Astepper1.run();
parseData();
showNewData();
And, while it probably makes no difference to the performance it would seem more logical to us humans if it was like this
parseData();
showNewData();
Astepper1.run();
...R
PS. I'm not sure it is a good idea to use //////// as separators. IIRC there are some combinations of that which the compiler chokes on. I always use something like //============
I have more questions, but I will try to get my analog sensor readings incorporated first. I already see that I will have a problem with single steps per loop between each analog reading.
I will give this a shot and add more to this later.
I am back at this again and I would like to see if i can get some more guidance.
Bellow is a sketch that works with my light sensor by using a light source at either above or below a set value. “UserRange = 500”
If light is < range. the stepper moves (-)
It light is > range. the stepper moves (+)
If else, then it stops.
if (RawToLux(rawValue) < UserRange) {
Astepper1.move(-10); // Set the position to move to
Astepper1.run(); // Start moving the stepper.
else if (RawToLux(rawValue) > UserRange) {
Astepper1.move(+10); // Set the position to move to
else {
Astepper1.stop();
BUT, being that it is impossible to maintain a constant Lux value I would like to assign it to a range. Maybe something like having a variable = +100 and -100 from the UserRange of 500 so that it would take a significant change in lighting to re position the stepper.
Is there a way to set a range to a variable? I tried using constrain() but I find it requires map()? and I do not need to remap. I am a bit lost again.
Any advice is greatly appreciated.
//Intent!
//To obtain serial data from a light sensor and
//use it to adjust the positioning of stepper
//to keep a room at a constant brightness.
//===Stepper Setup=================================================================================
long TravelX; // Variable used to store the X value entered in the Serial Monitor.
int move_finished = 1; // Variable used to check if stepper move is completed.
long initial_homing = -1; // Variable used to Home Stepper at startup.
//Associates the Accel Stepper Library for use with the Adafruit Motor Shield. "I think!".
AccelStepper Astepper1(forwardstep1, backwardstep1); // use functions to step from Adafruit Motor Shield.
const byte numChars = 32; //"const" makes the variable Read-Only never to change.
char receivedChars[numChars]; //An array to store the received data.
boolean newData = false; //boolean for "off,false or 0"
#define home_switch 18 // Defines Pin 9 too Home Switch.
//===Analog Light Sensor================================================================
//Connect 5v to VCC and GND to GND
//Connect 3.3v to the AREF pin
int sensorPin = A8; // Analog input pin for the GA1A1S202WP Analog Light Sensor (Lux Scale).
float rawRange = 1024; // 3.3v
float logRange = 5.0; // 3.3v = 10^5 lux
float RawToLux(int raw)
float logLux = raw * logRange / rawRange;
return pow(10, logLux);
int rawValue = analogRead(sensorPin); // read the raw value from the sensor:
int UserInput = 500; //User prefered light level Input PIN.
int UserRange = 500; //User prefered light level Range from Input.
int HomeStep = 0; //Home step.
int MaxStep = 2000; //Max blinds travel.
//int Lux1 = (RawToLux(rawValue) >= 0 && RawToLux(rawValue) <= 99);
//int Lux2 = (RawToLux(rawValue) >= 100 && RawToLux(rawValue) <= 499);
analogReference(EXTERNAL); //Analog Light Sensor
delay(5);
initial_homing++; // Increase by 1 for next move if needed // Sets Stepper to Roll up blind till home.
delay(5);
initial_homing = 1;
Astepper1.run();
initial_homing--; // Decrease by 1 for next move if needed.
delay(5);
Serial.println("");
//===End Void Setup=================================================================================
//===Analog Light Sensor Loop================================================================
Serial.println(RawToLux(rawValue));
delay(10); //This works, but it REALLY SLOWS DOWN the steper.....
//===Lux Range Loop=================================================================================
/* //This is for future ranges...
if (UserInput >= 0 && UserInput <= 99) {
UserRange = Lux1;
if (UserInput >= 100 && UserInput <= 499) {
UserRange = Lux2;
if (UserInput >= 500 && UserInput <= 1499) {
UserRange = Lux3;
if (UserInput >= 1500 && UserInput <= 4999) {
UserRange = Lux4;
if (UserInput >= 5000 && UserInput <= 9999) {
UserRange = Lux5;
if (UserInput >= 10000 && UserInput <= 24999) {
UserRange = Lux6;
if (UserInput >= 25000 && UserInput <= 49999) {
UserRange = Lux7;
if (UserInput >= 50000 && UserInput <= 74999) {
UserRange = Lux8;
if (UserInput >= 75000 && UserInput <= 119999) {
UserRange = Lux9;
//=== This is the area in question ======================
else {
Astepper1.stop();
//===Stepper Loop for direct step input in serial monitor=======================================
/* recvWithEndMarker();
parseData();
showNewData();
Astepper1.run();
//===End Void Loop=================================================================================
char rc;
rc = Serial.read();
ndx++;
ndx = numChars - 1;
else {
ndx = 0;
newData = true;
void parseData() {
Serial.print("Moving to position ... ");
newData = false;
//===Credits=====================================================================
//Brainy-Bits.com.
//Adafruit.com Forum.
//Arduino Forum and "Robin2".
Next, i have 9 buttons on a webpage i am trying to set so i can have the variable "UserRange" assigned to 9 different numbers. an example of a single variable is bellow.
if (client.read() == "Range1") {
UserRange = 250; //User prefered light level Range from Webpage.
Serial.println("UserRange"); //Verify output is as intended.
i keep getting this in the serial monitor and not the 250 i wanted.
GET /Range1 HTTP/1.1
new client
I will post the entire new sketch if i can get it below character limit.
//==== WiFi Initialization
#include <SPI.h>
#include <WiFi101.h>
IPAddress ip(192, 168, 1, 110);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
char ssid[] = "NETGEAR";
char pass[] = "xxxx";
int keyIndex = 0;
int status = WL_IDLE_STATUS;
WiFiServer server(80);
//===Stepper Initialization
long TravelX;
int Range1;
//===Analog Light Initialization
int sensorPin = A8;
int UserRange;
//==== WiFi Setup
WiFi.setPins(46, 47, 48);
WiFi.config(ip);
status = WiFi.begin(ssid, pass);
server.begin();
// print your WiFi shield's SSID:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
//==== WiFi Setup ==================================================
AFMSmid.begin();
delay(5);
delay(5);
initial_homing = 1;
Astepper1.run();
delay(5);
Serial.println("");
//Serial.println(RawToLux(rawValue));
//delay(10); //This works, but it REALLY SLOWS DOWN the steper.....
WiFiClient client = server.available(); // listen for incoming clients
String request = client.readStringUntil('\r'); // Read the first line of the request
Serial.println(request);
client.flush();
//======== Web Page Loop ============================================
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
if (currentLine.length() == 0) {
// client.println("HTTP/1.1 200 OK");
// client.println("Content-type:text/html");
// client.println(); // if the byte is a newline character
//----Start of web page.------------------------------------------------------------------------------
client.println("<html>"); // Beginning of web page.
client.println("<center>");
client.println(" Blind Mode Selection!
client.println("<a href=\"/Blinds=Manual\"\"><button>Manual </button></a>");
client.println("<a href=\"/Blinds=Auto\"\"><button>Auto </button></a>
client.println("<a href=\"/Range1\"\"><button>Range: 1 </button></a>
client.println("<a href=\"/Range2\"\"><button>Range: 2 </button></a>
client.println("<a href=\"/Range3\"\"><button>Range: 3 </button></a>
client.println("<a href=\"/Range4\"\"><button>Range: 4 </button></a>
client.println("<a href=\"/Range5\"\"><button>Range: 5 </button></a>
client.println("<a href=\"/Range6\"\"><button>Range: 6 </button></a>
client.println("<a href=\"/Range7\"\"><button>Range: 7 </button></a>
client.println("<a href=\"/Range8\"\"><button>Range: 8 </button></a>
client.println("<a href=\"/Range9\"\"><button>Range: 9 </button></a>
client.println("</html>");
//----End of web page.------------------------------------------------------------------------------
client.println(); // The HTTP response ends with another blank line:
break; // break out of the while loop:
// client.stop(); // close the connection:
// Serial.println("client disonnected");
if (RawToLux(rawValue) < UserRange - 250) {
else if (RawToLux(rawValue) > UserRange + 250) {
else {
Astepper1.stop();
parseData();
showNewData();
Astepper1.run();
char rc;
rc = Serial.read();
ndx++;
ndx = numChars - 1;
else {
ndx = 0;
newData = true;
void parseData() {
newData = false;
