18:51:59.044 -> Data Sent Message 0 Tx failed
18:52:00.139 -> Data Sent Message 0 Tx failed
18:52:01.234 -> Data Sent Message 0 Tx failed
18:52:02.328 -> Data Sent Message 0 Tx failed
18:52:03.455 -> Data Sent Message 0 Tx failed
18:52:04.549 -> Data Sent Message 0 Tx failed
18:52:05.643 -> Data Sent Message 0 Tx failed
18:52:06.737 -> Data Sent Message 0 Tx failed
My top suggestions for getting the rf24 modules to work:
If you read and, closely, follow Robin2's simple rf24 tutorial you should be able to get them working. That tutorial sure helped me. Run the CheckConnection.ino (look in reply #30) to verify the physical wiring between the radio module and its processor (Arduino).
Make sure the rf24 power supply can provide enough current. This is especially true for the high power (external antenna) modules. I use homemade adapters like these. They are powered by 5V and have a 3.3V regulator on the board. Robin2 also has suggested trying with a 2 AA cell battery pack.
If using the high powered radios make sure to separate them by a few meters. They may not work too close together. Try the lower power settings.
Reset the radios by cycling power to them after uploading new code. I have found that to help. They do not reset with the Arduino.
Switch to 1MB data rate to catch the not so cloned clones. radio.setDataRate( RF24_1MBPS );
I connected two arduino with NRF modules. I have uploaded the RF24 library. I downloaded the code from your post: Simple nRF24L01+ 2.4GHz transceiver demo - #2 by Robin2 I uploaded one sketch (master) on one arduino, the other (slave) on the other arduino. The diode is flashing, but as you can see the error.
In case you aren't noticing, respondents are beginning to walk you through, step by step, all the same things you probably didn't read, or didn't believe, when you did your research.
We can't do this for you.
Can you honestly say you have spent enough time with Robin2's tutorial, and need help yet?
Enough time, it's gonna be some time and work. Again, that's on you.
I did what here: I connected the module to the arduino with 7 wires and uploaded the code from the second post. Master and slave for 2 arduino with two NRF24l01 modules. WHAT CAN BE WRONG??????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
i have checked wires more than 10 times! in post 3 there is a "checkconnection" suggestion i made it and it doesn't seem that the modules are communicating with arduino.
