Possible Bug in the burn Bootloader function with JTAG?
Hello,
so i tried to burn the bootloader to a at32u4 on my own board using JTAG.
But after the execution of the comman throu the Arduino interface, my Chip is "Bricked". AVR-Dude gives the following Output:
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cjtag3 -B0.1 -e -Ulock:w:0x3F:m -Uefuse:w:0xcb:m -Uhfuse:w:0xd8:m -Ulfuse:w:0xff:m
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : jtag3
         Setting bit clk period        : 0.1
avrdude: usbhid_open(): No device found
avrdude: Found CMSIS-DAP compliant device, using EDBG protocol
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : JTAGICE3
         Description     : Atmel AVR JTAGICE3 in JTAG mode
         ICE hardware version: 2
         ICE firmware version: 3.55 (rel. 130)
         Serial number   : J30200024641
         Vtarget         : 3.29 V
         JTAG clock megaAVR/program: 7500 kHz
         JTAG clock megaAVR/debug:   1000 kHz
         JTAG clock Xmega: 7500 kHz
         PDI clock Xmega : 4000 kHz
avrdude: JTAG ID returned: 0x3f 0x70 0x58 0x49
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.07s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: erasing chip
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cjtag3 -B0.1 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/caterina/Caterina-Micro.hex:i -Ulock:w:0x2F:m
         Using Port                    : usb
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: WARNING: invalid value for unused bits in fuse "lock", should be set to 1 according to datasheet
This behaviour is deprecated and will result in an error in future version
You probably want to use 0xff instead of 0x3f (double check with your datasheet first).
avrdude: 1 bytes of lock verified
avrdude: reading input file "0xcb"
avrdude: writing efuse (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xcb:
avrdude: load data efuse data from input file 0xcb:
avrdude: input file 0xcb contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xd8"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xd8:
avrdude: load data hfuse data from input file 0xd8:
avrdude: input file 0xd8 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xff"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xff:
avrdude: load data lfuse data from input file 0xff:
avrdude: input file 0xff contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude done.  Thank you.
         .... i had to cut something to stay under 9000 Signs...
         Vtarget         : 3.29 V
         JTAG clock megaAVR/program: 10000 kHz
avrdude: bad response to AVR sign-on command: 0xa0
avrdude: retrying with external reset applied
avrdude: JTAGEN fuse disabled?
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
Fehler beim Brennen des Bootloaders.
So what it is telling me, if i get it right, is that it has programmed the fuse bits to:
avrdude: writing lock (1 bytes): 0x3F
avrdude: writing efuse (1 bytes): 0xcb
avrdude: writing hfuse (1 bytes): 0xd8
avrdude: writing lfuse (1 bytes): 0xff
Putting these Values into this awesome calculator, tells me that it has just disabled JTAG...
Now programming over JTAG obviously means it wont work any more. Is this a intended behaviour, an error on the calcs side, or a bug?
Thanks for having a look!
This may help:
Setting fuses on ATmega32u4
Reset mangled fuses atmega32u4
Those are the correct fuses for the Leonardo.
