Hello everyone.
I have made a small modification to the code to stop it "pausing" at each end; it looks like the first and last LED's are on for twice as long as the others (because they are
I can't figure out if this is the right place to post this, can someone please let me know if it is not. Thank you.
int timer = 100;Â Â Â Â Â // The higher the number, the slower the timing.
 // use a for loop to initialize each pin as an output:
 for (int thisPin = 2; thisPin < 8; thisPin++) {
  pinMode(thisPin, OUTPUT);
 // loop from the lowest pin to the highest:
  // turn the pin on:
  digitalWrite(thisPin, HIGH);
  delay(timer);
  // turn the pin off:
  digitalWrite(thisPin, LOW);
 // loop from the highest pin to the lowest:
 for (int thisPin = 7; thisPin >= 3; thisPin--) {
  // turn the pin on:
  delay(timer);
As you can see it is a small change, but sometimes I find those to be the most interesting ![]()
