I moved setup() and loop() above your functions:
Coal Creek Interlocking
\ s4b
s2___b2________s4a-4 ______\t5-5________________________________________s9-9______ _______b4________________
\t6-6 /t8
s1___b1________ ____________________\_________________/_______________s10a-10_____ _______b3________________
s3-3 \t7-7
\ s10b
Data Assignments
Address Pins
Strobe Pini
Byte0 Pins
Byte1 Pins
Address Data Byte
OUTPUTS
DisSignal_1 0 0
DisSignal_2 0 1
Signal_3 1 0
Signal_4a 1 1
Signal_9 2 0
Signal_10a 2 1
Signal_10b (d) 3 0, bit 0-3
Signal_4b (d) 3 0, bit 4-7
Lever_Locks 3 1
INPUTS
Levers 4 0
Blocks 4 1
const int Normal = 0;
const int Reverse = 1;
const byte Proceed = 0; // R/G
const byte Approach_Medium = 1; // Y/G
const byte Clear_Medium = 2; // R/G
const byte Approach = 3; // Y/R
const byte Restricting = 4; // R/Y
const byte Stop = 5; // R/R
const byte Top_Red = 1; //Define bits for aspect colors
const byte Top_Yellow = 2; //These can be added to produce the signal display
const byte Top_Green = 4;
const byte Bottom_Yellow = 16;
const byte Bottom_Green = 32;
const byte Bottom_Red = 64;
const int Distant_Signal_1 = 0;
const int Distant_Signal_2 = 1;
const int Signal_3 = 2;
const int Signal_4a = 3;
const int Signal_4b = 4;
const int Signal_9 = 5;
const int Signal_10a = 6;
const int Signal_10b = 7;
const int Lever_3 = 1; //Turnout
const int Lever_4 = 2; //Turnout
const int Lever_5 = 4; //Signal
const int Lever_6 = 8; //Signal
const int Lever_7 = 16; //Signal
const int Lever_8 = 32; //Signal
const int Lever_9 = 64; //Turnout
const int Lever_10 = 128; //Turnout
const int Block_1 = 0;
const int Block_2 = 1;
const int Block_3 = 2;
const int Block_4 = 3;
const int Turnout_5 = 0;
const int Turnout_6 = 1;
const int Turnout_7 = 2;
const int Turnout_8 = 3;
unsigned long Lever_Lock_Timer[] = {
0, 0, 0, 0, 0, 0, 0, 0}; //Turnout release delay time in milliseconds
byte GLevers; //Evaluated in Setup and must pass to Loop
byte GBlocks; //Evaluated in Setup and must pass to Loop
// Assign Pin Functions
//Address
pinMode(14, OUTPUT);
pinMode(15, OUTPUT);
pinMode(16, OUTPUT);
pinMode(17, OUTPUT);
pinMode(18, OUTPUT);
pinMode(19, OUTPUT);
pinMode(20, OUTPUT);
pinMode(21, OUTPUT); //strobe
//Output byte 0
pinMode(22, OUTPUT);
pinMode(23, OUTPUT);
pinMode(24, OUTPUT);
pinMode(25, OUTPUT);
pinMode(26, OUTPUT);
pinMode(27, OUTPUT);
pinMode(28, OUTPUT);
pinMode(29, OUTPUT);
//Output byte 1
pinMode(30, OUTPUT);
pinMode(31, OUTPUT);
pinMode(32, OUTPUT);
pinMode(33, OUTPUT);
pinMode(34, OUTPUT);
pinMode(35, OUTPUT);
pinMode(36, OUTPUT);
pinMode(37, OUTPUT);
//Input byte 0
pinMode(38, INPUT);
pinMode(39, INPUT);
pinMode(40, INPUT);
pinMode(41, INPUT);
pinMode(42, INPUT);
pinMode(43, INPUT);
pinMode(44, INPUT);
pinMode(45, INPUT);
//Input byte 1
pinMode(46, INPUT);
pinMode(47, INPUT);
pinMode(48, INPUT);
pinMode(49, INPUT);
pinMode(50, INPUT);
pinMode(51, INPUT);
pinMode(52, INPUT);
pinMode(53, INPUT);
//Initialize railroad
//Read Railroad
int Return_Data;
Load_Address (4); //Levers in byte 0, blocks in byte 1
Return_Data = Read_Input(); //Returns the values of the input pins 38 - 53 as an integer
GLevers = Return_Data & 255; //Extract byte 0, Position data on all 8 levers
GBlocks = Return_Data & 65280; //Extract byte 1
void Load_Address (byte Address) {
//Sets the address register, pins 14 - 20
int i;
int j;
int Address_Pin;
for (i = 0; i < 7; i++) {
Address_Pin = i + 14;
if (bitRead(Address, i) != 0) {
digitalWrite(Address_Pin, HIGH);
else {
digitalWrite(Address_Pin, LOW);
int Read_Input() {
int i;
int Result = 0;
int Start = 38;
for (i = 0; i < 16; i++) {
if (digitalRead(i + Start) != 0) {
Result = Result + bit(i);
return Result;
byte Set_Aspect_Colors (byte Aspect_Colors) { //Aspect_Colors enters as a value of 0 to 5
switch (Aspect_Colors) {
case Proceed:
Aspect_Colors = Top_Green + Bottom_Red;
case Approach_Medium:
Aspect_Colors = Top_Yellow + Bottom_Green;
case Clear_Medium:
Aspect_Colors = Top_Red + Bottom_Green;
case Approach:
Aspect_Colors = Top_Yellow + Bottom_Red;
case Restricting:
Aspect_Colors = Top_Red + Bottom_Yellow;
case Stop:
Aspect_Colors = Top_Red + Bottom_Red;
default:
return Aspect_Colors; //Aspect_Colors is returned with the sum of the bit values
void Load_Output (byte Data0, byte Data1) {
//Load output data in two bytes on pins 22 - 29 and 30 - 37
void Strobe() {
digitalWrite(21, HIGH);
delay(1);
digitalWrite(21, LOW);
Compiles fine for me.
