Hello,
I have an Adafruit Feather RP2040, with an Adafruit Music Maker FeatherWing (non amplified) on top, and an Adafruit 20W amplifier controlled via I2C on the feather. I have these set up in the empty shell of a retro 80s boombox, along with:
- 12V 30A power supply
- [multiple strips of 12V WS2811 string lights
- 12V to 5V stepdown converter to power the feather directly from the 12V power supply.
- a logic level converter
I've hooked up the following connections:
- on 12V power supply, hot to hot, neutral to neutral, ground to ground
- +5V output from step down converter directly to the USB pin on the feather & to the 12V power screw block on the 20W amp
- -5V from step down converter going to feather's GND pin & -12V screw block on 20W amp
The power supply has 3 sets of screws for the 12V bus, list of what's on each:
- 1 set of lights' +/-
- 2nd set of lights' +/-
- the 12V side of the stepdown converter
Finally, the data line of the lights go from Feather -> Logic level converter (from 3.3v to 5v) -> Lights. The logic level converter LV is plugged into the 3.3V bus on the Feather, with the HV plugged into the USB/5V pin on the Feather.
I am using Arduino IDE with the FastLED library to program this. I have a fairly complex program set up on the feather that plays music, and adjusts the lights as though they were Christmas lights with the occasional special effects. When I test things with the feather plugged into my laptop's USB (& 12V PS off to not fry my laptop), everything works perfectly, even powering the 12V lights (I limit it to 1 strip to not kill the feather, or my laptop USB port) with 5V. However, when I unplug USB, and plug in mains power to the power supply, the feather powers fine, and executes the program fine, but the LEDs do not light correctly--they'll flicker weirdly, and usually will be the wrong color. I've heard that a common issue is grounding when lights don't behave as expected, but I've tried the following ways to ground:
- Connected Feather's GND to the 12V supply chassis
- Connected Feather's GND to the GND of the mains input
- Connected Feather's GND to -12V bus
However, the problem persists in each case. I'm kinda out of ideas as to what I'm missing. Any ideas?
