Possible I2C issue (0.96 SSD1306 & MCP9808)
Good afternoon everyone!
I have an issue connecting 0.96 inch OLED display (SSD1306) and Adafruit MCP9808 together. They are sitting on the same line. I think that it is a clash of registers for some reason.
Here is my sketch that I am trying to get to work.
  GraphicsTest.ino
  Some graphics/text output for U8x8 API
  Universal 8bit Graphics Library (https://github.com/olikraus/u8g2/)
  Copyright (c) 2016, olikraus@gmail.com
  All rights reserved.
  Redistribution and use in source and binary forms, with or without modification,
  are permitted provided that the following conditions are met:
  * Redistributions of source code must retain the above copyright notice, this list
    of conditions and the following disclaimer.
  * Redistributions in binary form must reproduce the above copyright notice, this
    list of conditions and the following disclaimer in the documentation and/or other
    materials provided with the distribution.
  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
  CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
  INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
  MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
  CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
  NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
  LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
  STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
  ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <Arduino.h>
#include <U8x8lib.h>
#include "Adafruit_MCP9808.h"
U8X8_SSD1306_128X64_NONAME_SW_I2C u8x8(/* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE);   // OLEDs without Reset of the Display
Adafruit_MCP9808 tempsensor = Adafruit_MCP9808();// Create the MCP9808 temperature sensor object
void setup(void)
  u8x8.begin();
  tempsensor.begin();
void temp(void)
  float c = tempsensor.readTempC();
  u8x8.setCursor(0,2);
  u8x8.print("Temp C:");
  u8x8.print(c);
  tempsensor.shutdown_wake(1); // shutdown MSP9808 - power consumption ~0.1 mikro Ampere
  tempsensor.shutdown_wake(0);
void pre(void)
  u8x8.setFont(u8x8_font_amstrad_cpc_extended_f);
  u8x8.clear();
  u8x8.inverse();
  u8x8.print(" TEMPERATURE   ");
  u8x8.setFont(u8x8_font_chroma48medium8_r);
  u8x8.noInverse();
  u8x8.setCursor(0,1);
void loop(void)
  pre();
  temp();
  u8x8.print("github.com/");
  delay(2000);
  u8x8.setCursor(0,3);
  u8x8.print("Tile size:");
  u8x8.print((int)u8x8.getCols());
  u8x8.print("x");
  u8x8.print((int)u8x8.getRows());
Thank you in advance!
The first thing you need to find is the I2C address of each device?
Have you tried the examples for each device separately?
PS
The two devices have selectable address values and neither set overlap. That is not your problem. Again, try the examples for each device separately.
