However I have used standard shielded alarm 8 core cable to connect the switches which has been placed in the same plastic pipe as the single core mains cables. In other words it travels about 10m along the mains cables, in parallel.
[Now, this is a bad practice and also violates electricity wiring rules (low voltage cables in the same conduit as mains cabling), however I did it since there was no other choice!]
Now, apparently I am experiencing spontaneous, ie erratic readings on the output of the PCF chip. Some switches are wrongly detected to be spontaneously on. I am therefore suspecting that this is due to mains interference.
Please note that nearby mains cabling only carry very low currents for LED lighting, ie less than 0.2A and most times is even zero. Erratic operation happens regardless however.
In order to improve operation, I am now thinking to solder 0.1nf- 1uF caps across each of the diodes in the circuit.
What do you think of my diagnosis above?
Do you anticipate that adding the caps this will have any benefit?
I may assume there's a ninth wire - the ground return - to the switches? You don't mention this nor have it in your schematic.
10m is a long wire to pick up interference. Capacitors can help a lot - 100 nF is normally more than enough for that. Stronger pull-ups help as well, I see you already have 4k7 there. You may lower that value even more, to 2k2 or even 1k.
In addition to the diodes you need to add capacitors from the input to ground as close to the IC as possible / practical.
Although you have a pretty good current going to the switches, such a long distance where coupling to the mains will cause significant pickup you still need some low pass filtering at the IC.
What is not clear by your schematic is the routing of the ground for the 8 inputs. There could be more corruption of the input signals if the switch ground is also subject to pickup in your conduit.
The ground is just one of the wires in the multicore cable and in addition the cqble shield is also grounded.
wvmarle:
The input resistors should not be too large, as they form a voltage divider with the pull-up resistor, lowering the voltage at the pin.
That is of course because they are wired wrongly.
The pull-ups go on the cable (switch) side of the series resistors. The series resistors - which are mounted close to the microcontroller - can be quite a high value - 10k or more. The diodes and capacitors go on the microcontroller side of the series resistors.
The point of protection diodes is to prevent voltages below about -0.3 or above Vcc+0.3V reaching the
pins of the chip. Vcc varies, its 0V when the chip is powered down but the protection should still work,
which is why schottky diodes to GND/Vcc are typically used, with a current limiting resistor to protect the
schottkys. Using 50 to 220 ohm series resistors also soaks up reflections on the wires, which is why such
values are typically used - especially for clocking signals where a double pulse would cause malfunction.
For low bandwidth signals all you actually need is a 10k series resistor and small cap to ground 10nF or 100nF,
the 10k resistor fully protects against spikes(*), the capacitor prevents RF and noise affecting the signal. Any
pull-up should be directly to the incoming wire before such a large series resistor.
(*) Protection diodes can handle a fraction of a mA OK, and unless you have a very rare CMOS chip with no protection diodes its inputs, this is the simplest protection for slow signals.
I won't comment about signal and mains in the same conduit, but if you could change the signal wires, I would suggest:
Best foil shielded
next woven shielded
last twisted
Thanks for the info.
The signal cable is of the woven shielded type (copper wire shield)
Therefore there is no point in replacing the cable with cat5 twisted pair unless its of the STP type.
Thats why I had the 220R series resistors but I understand that you are saying that the pullups should come before (from the switches side) the series resistors.
For low bandwidth signals all you actually need is a 10k series resistor and small cap to ground 10nF or 100nF,the 10k resistor fully protects against spikes(*), the capacitor prevents RF and noise affecting the signal.
Bit confused now. Is this 10k resistor instead of the 220R mentioned earlier?
That looks about right to me.
Those zeners are not needed - if you want to protect against spikes you can do two things.
a) replace the 220R resistors by 10k ones, and let the Arduino's clamping diodes take care of it, normally this will do the job just fine.
b) add two Schottky diodes - one between signal and Vcc, the other between signal and GND.
For the remaining spurious readings: these are likely to be very short (a few milliseconds) and therefore easy to distinguish from a human pressing the button (who will struggle to press it for shorter than 100 ms). Modified debouncing should actually take care of most of those spikes: instead of ignoring presses for 50 ms or so after the first falling edge, register the button press only when it's been pressed for at least 50 ms. Of course that does mean your button has that long a reaction time after being pressed but you're not likely to notice this (50 ms is a very short time for a human).
Remember that these inputs are connected to a port expander PCF8574, not the arduino μC.
Not sure if the PCF has input clamp diode... although there is a reference for "input diode clamp voltage" in the datasheet.
Thats why I installed zeners just in case...
