Possible noise on encoders
Can anyone see where I am going wrong?. I am thinking it may be noise. If I spin the motors by hand I get good signals with no missed counts forward and reverse, when I turn on the motors I get garbled signals as shown at bottom of sketch. I removed both wires from one of the motors and wired the motor direct with a battery and the signals were good again, I will try to upload a fritzing of circuit. I have four different battery feeds trying to prevent noise, with all the grounds connected but looks like I have failed. i am using a nano with L298n driver and the encoders are built into the motors I believe hall sensors, The batterys are 11.1v for motors 7.4v for nano 3.7v for encoders and 7.4v reduced to 5v for pots and other stuff later.
#include <PinChangeInt.h>
#include <LMotorController.h>
const byte L_EncA = 9;
const byte L_EncB = 11;
const byte R_EncA = 10;
const byte R_EncB = 12;
int Pwm_A = 3;
int L_motorA = 4;
int L_motorB = 5;
int R_motorA = 7;
int R_motorB = 8;
int Pwm_B = 6;
LMotorController motorController(Pwm_A, L_motorA, L_motorB, Pwm_B, R_motorA, R_motorA, 0, 0);
#define TOTAL_PINS 21
volatile uint16_t interrupt_count[TOTAL_PINS] = {0};
volatile uint16_t interrupt_count1[TOTAL_PINS] = {0}; // possible arduino pins
volatile int L_Enc_A_Pos = 0;
volatile int R_Enc_A_Pos = 0;
int i;
int j;
#define Encoder_Print;
pinMode(L_EncA, INPUT_PULLUP);
pinMode(L_EncB, INPUT_PULLUP); // Encoder
digitalWrite(L_EncA, HIGH);
PCintPort::attachInterrupt(L_EncA, quicfunc0, FALLING);
pinMode(R_EncA, INPUT_PULLUP);
pinMode(R_EncB, INPUT_PULLUP); // Encoder
digitalWrite(R_EncA, HIGH);
PCintPort::attachInterrupt(R_EncA, quicfunc1, FALLING);
//Potentiometer pins
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(L_motorA, OUTPUT);
pinMode(L_motorB, OUTPUT);
pinMode(R_motorA, OUTPUT);
pinMode(R_motorB, OUTPUT);
pinMode(Pwm_A, OUTPUT);
pinMode(Pwm_B, OUTPUT);
void quicfunc0() {
if (digitalRead(L_EncA) == digitalRead(L_EncB)) {
L_Enc_A_Pos++;
L_Enc_A_Pos–;
#ifdef Encoder_Print;
Print();
#endif
void quicfunc1() {
if (digitalRead(R_EncA) == digitalRead(R_EncB)) {
R_Enc_A_Pos–;
R_Enc_A_Pos++;
Print();
#endif
int count;
int count1;
for (i = 0; i < TOTAL_PINS; i++) { //Less than TotalPins
if (interrupt_count != 1) { // look at all the interrupted pins
count = interrupt_count*; // store its count since the last iteration*
interrupt_count = 0; // and reset it to 0
* for (j = 0; j < TOTAL_PINS; j++) {
if (interrupt_count1[j] != 0) {
count1 = interrupt_count1[j];
interrupt_count1[j] = 0;
_ }
int value = analogRead(A0);
value = map(value, 0, 1023, -255, 255);
if (value >= 0)
{_
digitalWrite(L_motorA, HIGH);
digitalWrite(L_motorB, LOW);
analogWrite(Pwm_A, -value);
digitalWrite(R_motorA, HIGH);
digitalWrite(R_motorB, LOW);
analogWrite(Pwm_B, -value);
_ } else*
* {_
digitalWrite(L_motorA, LOW);
digitalWrite(L_motorB, HIGH);
analogWrite(Pwm_A, value);
digitalWrite(R_motorA, LOW);
digitalWrite(R_motorB, HIGH);
analogWrite(Pwm_B, value);
_ }
void Print() {_
Serial.print("L_Encoder “);
Serial.println(L_Enc_A_Pos);
_ Serial.print(” ");_
Serial.print("R_Encoder ");
Serial.println(R_Enc_A_Pos);
_}
//-------------------------------------------------------_
L_Encoder 1
R_Encoder 0*
L_Encoder 2
* R_Encoder 0*
L_Encoder 3
* R_Encoder 0*
L_Encoder 3
* R_Encoder 1*
L_Encoder 4
* R_Encoder 1*
L_Encoder 5
* R_Encoder 1*
L_Encoder 5
* R_Encoder 0*
L_Encoder 6
* R_Encoder 0*
L_Encoder 6
* R_Encoder -1*
L_Encoder 6
* R_Encoder 0*
L_Encoder 6
* R_Encoder 1*
L_Encoder 5
* R_Encoder 1*
L_Encoder 5
* R_Encoder 2*
L_Encoder 5
* R_Encoder 3*
L_Encoder 4
Please edit your post to add code tags, as described in "How to use this forum".
int Pwm_A   =  3;
int L_motorA = 4;
int L_motorB = 5;
int R_motorA = 7;
int R_motorB = 8;
int Pwm_B    = 6;
int i;
int j;
 pinMode(A0, INPUT);
 pinMode(A1, INPUT);
 pinMode(A2, INPUT);
void quicfunc0() {
   L_Enc_A_Pos++;
   L_Enc_A_Pos--;
 Print();
#endif
void quicfunc1() {
   R_Enc_A_Pos--;
   R_Enc_A_Pos++;
 Print();
#endif
 int count;
 int count1;
     count = interrupt_count;               // store its count since the last iteration
 if (value >= 0)
 } else
void Print() {
 Serial.print("L_Encoder    ");
 Serial.print("                        ");
L_Encoder    1
                       R_Encoder    0
L_Encoder    2
                       R_Encoder    0
L_Encoder    3
                       R_Encoder    0
L_Encoder    3
                       R_Encoder    1
L_Encoder    4
                       R_Encoder    1
L_Encoder    5
                       R_Encoder    1
L_Encoder    5
                       R_Encoder    0
L_Encoder    6
                       R_Encoder    0
L_Encoder    6
                       R_Encoder    -1
L_Encoder    6
                       R_Encoder    0
L_Encoder    6
                       R_Encoder    1
L_Encoder    5
                       R_Encoder    1
L_Encoder    5
                       R_Encoder    2
L_Encoder    5
                       R_Encoder    3
L_Encoder    4
There are several major problems with that code.
  1. Never attempt to print from within an interrupt routine. Printing depends on interrupts, which are off in an interrupt routine.
  2. Multibyte variables shared with interrupts must be protected from corruption.
For example in the line below, R_Enc_A_Pos can be corrupted by an interrupt during the print operation.
You need to do something like this, printing from the main program:
cli(); //turn off interrupts
int temp= R_Enc_A_Pos; //make a copy
sei(); //turn interrupts back on
 Serial.println(temp); //print the copy
  1. What is all this supposed to do? Did you copy/paste from your corrupted post above?
  1. The analogWrite() value must be 0-255. What does the following do?
 if (value >= 0)
Ok thanks for your reply, lots of errors, I mapped the analogwrite just to run the motors from the pot untill i sort out this problem, at zero or center of pot the motors stop the neg value runs motors in reverse and pos run in forward. maybe wrong but that works. As for the total pins i had that bit of code from a previous code with pinchange and thought it was needed to use all pins; can see that was wrong now. As for the interrupts I have changed the code; either I have wrote it wrong or it is still giving problems, the motors should give 616 counts per wheel revolution, the best results are on RISING but not right; worse when powered up.Thanks again.
//------------------------------Try to get both motors equal-----------------------------
byte L_EncA_Last;
byte R_EncA_Last;
int Pwm_A   =  3;
int L_motorA = 5;
int L_motorB = 4;
int R_motorA = 8;
int R_motorB = 7;
int Pwm_B    = 6;
  PCintPort::attachInterrupt(L_EncA, quicfunc0,  RISING);
  PCintPort::attachInterrupt(R_EncA, quicfunc1,  RISING);
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  pinMode(A2, INPUT);
void quicfunc0() {
    L_Enc_A_Pos++;
    L_Enc_A_Pos--;
void quicfunc1() {
    R_Enc_A_Pos--;
    R_Enc_A_Pos++;
 int Temp = L_Enc_A_Pos; //make a copy
  Serial.print(Temp);
 int temp = R_Enc_A_Pos; //make a copy
  Serial.print("                ");
  if (value >= 0)
  } else
Arr, just noticed that error bit better now, I'll give it more checks
  Serial.print(Temp);
  Serial.print("                ");
You might have motor noise in the power supply as well. Be sure your motors are bypassed with 10 nF capacitors, as described in this tutorial. Use twisted pair wiring for motor power leads.
Also, it never hurts to add capacitors, say 100 to 1000 uF cap across the power input terminals for the Arduino and 10 uF across the sensor power leads.
Please post a hand drawn (not Fritzing) wiring diagram.
They always get messy when I try to draw circuits, but this is about it. I did tempary try a 47 uf capacitor across the 11.1v input on the l298n before looking at code again. There are already some capacitors and resistors on the pcb of the encoders not sure what they do but could I think solder some more across the motors.
Having a problem uploading the jpg will try again later
A photo of the wiring is most informative. In particular where you route the encoder wiring compared
to high current motor and supply wiring is important, as is the nature of the cable and its length.
You’ve not posted details of the hardware (datasheets / product pages), please do so, otherwise we
have only a vague idea of what you have, and details always matter.
The photo just shows a bunch of wires, but as you say all mixed, I did think of maybe shielding the sensor wires then thought there are a lot of sensor wires in a car and they all go in a big loom together and not many of them are shielded. For the moment jremington seems to have sorted that problem I was printing inside the interrupt and thanks to him for pointing that out. I am just working on snippets one at a time, hopefully will put it all together one day. I have no data sheet on the encoders I just know it has 11 pulses per motor turn and I am using 56/1 gear ratio with 100mm dia wheels with 6.5 Kg.cm torque 12v, that is going to be trial and error for me.
