I want to build a basic MIDI controller using an Arduino, just a button and potentiometers, but I want it to be expandable. So, on the outside case of my little controller would it be possible to have some kind of inputs that would be wired to the Arduino, that I can plug other sensors into?
Maybe I could connect one Arduino with one set of sensors to the base Arduino?
I honestly dont really know what Im talking about, and what I said will probably need clarification, Im gonna try to do some sketches, thank you.
So after a bit of research, could I have an XBee unit thingy on the main module, and multiple slave XBee's with potentiometers and what not that connect to the main?
And as I understand it the slave XBee's can take in data from potentiometers and what not on their own, without an Arduino?
Well one method you could consider is using a shield designed to have external sensors and componets plugged into it.
Here they cover the whole product line:
