Possible solution to Nano every not Uploading Please confirm
I have bought A NoNo every Board
I cannot get compile to work
avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
I think reference to Nano every is missing from file
/home/pi/arduino-1.8.13/hardware/arduino/avr/boards.txt
I dont know what values to put in
See: Google Code Archive - Long-term storage for Google Code Project Hosting.
nano.name=Arduino Nano
nano.upload.tool=avrdude
nano.upload.protocol=arduino
nano.bootloader.tool=avrdude
nano.bootloader.unlock_bits=0x3F
nano.bootloader.lock_bits=0x0F
nano.build.f_cpu=16000000L
nano.build.board=AVR_NANO
nano.build.core=arduino
nano.build.variant=eightanaloginputs
Arduino Nano w/ ATmega328P
nano.menu.cpu.atmega328=ATmega328P
nano.menu.cpu.atmega328.upload.maximum_size=30720
nano.menu.cpu.atmega328.upload.maximum_data_size=2048
nano.menu.cpu.atmega328.upload.speed=115200
nano.menu.cpu.atmega328.bootloader.low_fuses=0xFF
nano.menu.cpu.atmega328.bootloader.high_fuses=0xDA
nano.menu.cpu.atmega328.bootloader.extended_fuses=0xFD
nano.menu.cpu.atmega328.bootloader.file=optiboot/optiboot_atmega328.hex
nano.menu.cpu.atmega328.build.mcu=atmega328p
Arduino Nano w/ ATmega328P (old bootloader)
nano.menu.cpu.atmega328old=ATmega328P (Old Bootloader)
nano.menu.cpu.atmega328old.upload.maximum_size=30720
nano.menu.cpu.atmega328old.upload.maximum_data_size=2048
nano.menu.cpu.atmega328old.upload.speed=57600
nano.menu.cpu.atmega328old.bootloader.low_fuses=0xFF
nano.menu.cpu.atmega328old.bootloader.high_fuses=0xDA
nano.menu.cpu.atmega328old.bootloader.extended_fuses=0xFD
nano.menu.cpu.atmega328old.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
nano.menu.cpu.atmega328old.build.mcu=atmega328p
Arduino Nano w/ ATmega168
nano.menu.cpu.atmega168=ATmega168
nano.menu.cpu.atmega168.upload.maximum_size=14336
nano.menu.cpu.atmega168.upload.maximum_data_size=1024
nano.menu.cpu.atmega168.upload.speed=19200
nano.menu.cpu.atmega168.bootloader.low_fuses=0xff
nano.menu.cpu.atmega168.bootloader.high_fuses=0xdd
nano.menu.cpu.atmega168.bootloader.extended_fuses=0xF8
nano.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
nano.menu.cpu.atmega168.build.mcu=atmega168
platform.txt (7.53 KB)
Tom1962:
Congratulations!
Tom1962:
If you got that message, it proves that compile worked perfectly. This is a message that happens during the upload. The upload doesn't even start if the compile didn't work, so we know for certain that you are mistaken in the impression: "I cannot get compile to work".
Tom1962:
This is a normal and expected message while uploading to the Nano Every. I can see from your screenshot that the upload was successful. So please just ignore this message and get back to having fun with Arduino.
Tom1962:
That is incorrect. That is the boards.txt file for the "Arduino AVR Boards" platform. The Nano Every is not a board of that platform. The boards platform of the Nano Every is "Arduino megaAVR Boards". If you found the boards.txt for the Arduino megaAVR Boards platform, you would see the definition for the Nano Every in that file.
Tom1962:
Please don't edit that file. There is no reason to do it and it will likely cause you problems later.
