Possible to "brick" an ATMEGA328 ? ... correct fuse settings question
Hi, is it possible to "brick" an ATMEGA328 with a wrong fuse setting? I have one chip and now my AVRFuse program can't talk to it anymore, can't read the current state of switches, etc. Is there a way to "revive" this?
So I popped out this problem chip, and inserted a new one... was also able to program this chip directly via ICSP successfully.
And the fuse settings I used are:
Low: 0xff High: 0xde Ext: 0x05
Are these values the recommended ones? Thanks.
Yes, especially if the wrong fuse for the cpu clock option is selected. See the ATmega328 data sheet for the fuse definitions.
I program all my 328Ps as an Uno. The fuse settings are found in the boards.txt file:
uno.bootloader.low_fuses=0xff uno.bootloader.high_fuses=0xde uno.bootloader.extended_fuses=0x05
So you seem to have those correct.
Any chance you messed with the lock bits? This is the totally unlocked state: uno.bootloader.unlock_bits=0x3F uno.bootloader.lock_bits=0x0F
The chip is never really totally bricked - you may just need a High Voltage programmer to unlock it (12V, so not all that high, but not something many people have - including me).
There are three easy ways to "brick" the ATmega328p with my ncorrect fuses: You can disable the Serial Programming feature. You can turn off the Reset Pin feature. You can select a system clock that is not implemented.
The clock can be fixed by using the version of ArduinoISP that generates an 8 MHz clock to be connected to the XTL1 pin of the target processor.
The other two require something like the High Voltage Rescue Shield 2 which plugs not an UNO and can use Parallel Programming to erase the chip and reset the fuses.
This fuse can not be changed by serial programming.
