Possible to update ESP8266 firmware?
Hello
I just bought a new ESP8266 developpment board. When I reset it I must set the baudrate at 74880. The board did't seem to accept AT command from a CoolTerm terminal.
After a reset, these info are sent to the serial monitor
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3460, room 16
tail 4
chksum 0xcc
load 0x3fff20b8, len 40, room 4
tail 4
chksum 0xc9
csum 0xc9
v00049d90
~ld
Any help appreciated
Martin
Hi @arjfca. Please tell us the reason you want to send AT commands to the ESP8266.
The AT firmware is useful if you want to use the ESP8266 as a Wi-Fi adapter for another Arduino board. However, most people these days just program the ESP8266 directly with an Arduino sketch, without bothering with the complexity of having two microcontrollers in the project. If you don't need to connect another Arduino board to the ESP8266, then there is no need for the AT firmware and you can skip that somewhat complicated process of installing it.
@arjfca you posted in the wrong section. I have moved it here. Please be careful where you post in future.
Which board exactly ?
For the reboot output that is the correct baud-rate, but most likely the Firmware that is loaded uses 115200kbps.
Try that and make sure you send 'Both CR & LF' as a line ending.
And please answer the questions in reply#2
