Possible with Arduino?
Is something like this even remotely possible with arduino (well at least the programming and servo controlling):
http://www.lynxmotion.com/Category.aspx?CategoryID=92
Thinking of starting a project much similar to that but with less features/functions … is arduino a good/possible choice ?
Any recommendations/suggestions, even about the rest of the stuff, radio, control, etc would be appreciated.
I think controllibg 18 servos directly with Arduino would be quite a task. You can get some l controller borads that can be serially controlled from Arduino and they can con trol some servos. Thats probably the easiest way to do it.
Check this (others exist as well) http://www.pololu.com/catalog/product/727
quite… however I recommend you use lynxmotion’s own SSC-32 servo controller
that way you can control up to 32 servos using nothing but a serial connection to the arduino. plus it’s quite affordable (~$35 USD)
I probably should have just included this link in my last post:
I built a hexapod using the arduino and SSC-32
Thats good advice. And a cheap way to control 32 servos.
