I teach Arduinos to 13yr olds. I made a kit of 12 clone UNOs. #6 has apparently died. They use the CH340 chip to connect. Both ON and L leds light up, but trying to upload anything hangs and fails.
The board connects to Windows (Ba-da-bing!) and shows up as COM15. But uploading fails each time. Example of verbose output is:
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM15
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x47
Where the resp=0x code varies. Sometimes it's 0x08. It repeats the 10 fails and gives up.
The loopback test fails. No response from serial monitor.
So I bought a clone USBtinyISP device to try and load a bootloader. After getting this installed with proper drivers and testing that it does flash a bootloader to other boards, I tried to use this on the dead board.
Output from Arduino is then:
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\\.\libusb0-0001--0x1781-0x0c9f
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: initialization failed, rc=-1
This was done with the jumpered power option on the USB tiny to power the Uno (which does light up while connected)
I have also tried flipping the 6 pin cable incase it was backwards, to no effect.
I have also previously tried to use Arduino as ISP with a genuine Arduino, but that failed as well.
Do I have a bricked UNO? I don't have any decent way to try and generate manual clock signals, and the kids using them I don't think could have set a FUSE anyway as we're just using the Arduino IDE and physical wires.
I've done a lot of googling and tried everything I have the tools for that I could find.
