possibly stuck in a loop
at the top of my code… both declared globally
int btm_reed = 9; //connected to pin 9 on uno
int btm_reeding = 1;
loop im stuck in, is btm_reeding ever getting updated?
while(btm_reeding = 1)
myservo.writeMicroseconds(1000);
myservo.writeMicroseconds(1500); //1500
btm_reeding=digitalRead(btm_reed);
Serial.println(“tea ball lowering”);
also tried this loop(var declared globally as well), but get stuck in it as well…
do
}while(btm_reeding = HIGH);
are the var (btm_reeding) and (top_reeding) dying at the end bracket? i did declare them globally.
if you're testing to see if two things are equal, rather than assigning a variable a value, you use == rather than =
"We all prisoners, chickee-baby. We all locked in."
Code tags please!
should be
 while(btm_reeding == 1)
that was my problem, thank you. i hate having little errors like that hold me up
