POST data to PHP via Arduino Uno WiFi Rev. 2
So as you can se below in the attached sketch, I am trying to POST some data to a php file, which then inserts the data into a MySQL Database. I used mysql connector for that, but that was too unstable for long term usage. I tried the POST with another app and it works, the php file does exactly what it should do. However, I cannot get it to accept data from Arduino. It always returns no data. Any help would be highly appreciated.
The code below is only part of the final script, but I broke it down to the essentials. In the original script, the query is a char array and not a String, for memory reasons. I only changed it to a String, to eventually filter out any problems there, but that did not help.
#include <SPI.h>
#include <WiFiNINA.h>
// EDIT: Change the 'ssid' and 'password' to match your network
char ssid[] = "seid";  // wireless network name
char password[] = "pass"; // wireless password
int status = WL_IDLE_STATUS;
WiFiClient client;
String query = "temp=2300&humid=5000&pressure=95000&windd=31500&winds=300&windg=400&rainr=0&rainh=0";
  // this check is only needed on the Leonardo:
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, password);
    // wait 10 seconds for connection:
    delay(10000);
  //pinMode(7, OUTPUT);
  if (client.connect("192.168.3.228",80))
       // REPLACE WITH YOUR SERVER ADDRESS
    Serial.println("connected");
    client.println("POST /insertmysql.php HTTP/1.1");
    client.println("Host: 192.168.3.228");
    client.println("Content-Type: application/x-www-form-urlencoded; charset=UTF-8");
    client.println();
    client.print(query);
  delay(2000);
  Serial.println("Response: ");
  while (client.connected() || client.available())
    Serial.write(client.read());
PHP File looks as follows:
<?php
$temp=$_POST["temp"];
$humid=$_POST["humid"];
$pressure=$_POST["pressure"];
$rainr=$_POST["rainr"];
$rainc=$_POST["rainh"];
$windd=$_POST["windd"];
$windg=$_POST["windg"];
$winds=$_POST["winds"];
echo('at least something');
echo json_encode($_POST);
// EDIT: Your mysql database; account information
$servername = "192.168.3.228";
$username = "name";
$password = "pass";
$dbname = "Wetter";
$test = 100;
// Create connection
$conn = mysqli_connect($servername, $username, $password, $dbname);
// Check connection
if (!$conn) {
    die("Connection failed: " . mysqli_connect_error());
$sql = "INSERT INTO alldata (T, Tmax, Tmin, H, P, W, G, R, RR, D, A, B, S) VALUES ($temp, $temp, $temp, $humid, $pressure, $winds, $windg, $rainc, $rainr, $test, $test, $windd, $test)";
echo($sql);
if (mysqli_query($conn, $sql)) {
    echo "New record created successfully";
    echo "Error: " . $sql . "
" . mysqli_error($conn);
mysqli_close($conn);
I tried to echo the _POST to understand what is received but that always gives me nonsense too.
Any help, as said before, highly appreciated.
Hi Minestrone,
just an FYI I am no pro user, in fact I just posted my first question in this forum 10 minutes ago. I saw your thread and it reminded of something I came across a few months back.
I was trying to do something similar to you, ultimately send sensor data to MySQL Database using PHP.
Look at using this: MySQL_Connector_Arduino it takes this PHP and POST completely out of the equation. The library handles the communication and you only need to focus on the Query strings.
in GitHub under the extras folder their is a .pdf manual which explains how to set up and use with good examples. The only draw back in the library is pretty large so if your using the UNO this might be an issue. I use the MEGA and it works perfectly.
Good Luck.
Hi Fordty,
thanks for the reply. as I wrote, I used the mysql connector library, but it has been too unstable (it randomly stopped to insert data after a few hours of continuous use).
But thanks anyway!
So for anyone ever trying to accomplish something simila, the main error was that this line
client.print("Content-Length: ");
client.println(thisLength);
was missing. With this line it works, although it is normally not a necessity to include this line.
