Post here for IDE 2.0 RC?
Shall this category be used for feedback on the 2.0 RC, or will there be a new one?
This is the correct place. I'm looking forward to seeing your feedback.
I'm running 1.8.5 (installed) in parallel with a zip install of RC2.
Some oberservations
  1. Splash screen on top of every open program; highly annoying.
  2. Autoformat seems extremely slow or not always working, even on a small sketch of 40 lines it can take 10 seconds or more without visible changes. I often think that it does not work and press <ctrl>T again after which it's there.
  3. The additional board urls (file -> preferences) are not populated (they are in 1.8.5) but the boards are there (e.g. Uno Wifi Rev2 and Sparkfun boards). I'm not sure how it's supposed to work, does it just look in appdata for additional boards?
  4. Enabling verbose output during compilation does not always give the desired effect; it just does not show the verbose output. I haven't figured out yet exactly what makes it behave as expected (might be by starting 1.8.5 first) but currently it is as expected on my system.
Question:
Is there support for a protable install? Or not yet.
Note:
Running a 2nd generation I3, Windows 10.
Thanks for the feedback @sterretje!
As someone who starts the IDE over and over again while beta testing, I very much agree. This frustrating user experience is tracked here:
The problem is that the Arduino Language Server handles the auto formatting. This tool also provides the code aware features like completion and problem detection, so it must process the sketch after every change, which inevitably takes some time. The auto format does not require this code awareness, yet is still blocked until the language server finishes with the processing.
This general sort of issue is being tracked here:
If you discover a specific set of operations you find reliably breaks the auto format, that would give the developers a better starting point for improving the reliability.
This can sometimes cause additional problems, such as the one reported here:
Arduino IDE 2.x uses a completely different preferences system from the classic Arduino IDE, and there is no automated transfer between the systems, so users must copy over their "Additional Boards Manager URLs" list and any other custom preferences settings when they make the transition to 2.x.
Yes, but you will only be able to install updates in Boards Manager if you have the 3rd party package index URLs in your preferences.
It might be this bug:
If the issue you observed has another cause, please let me know.
Not yet, the deficiency is tracked by the developers here:
@ptillisch, thanks.
I think that I have, in the past, seen most of my observations already come along here in this section of the forum. It's just that I (kind of) expected some of them to be ironed out in the RC2 :wink:
I do not start the IDE often (basically just once a day). The problem is that I have a sequence of actions when I start the day.
  1. I start my browser for forum, emails and so on
  2. I start the IDE
  3. I start reading forum posts or emails but that is very difficult with that splash screen on top of all applications.
