I did a post at Using C:B to program/use com port my first post and I was lock-up. My only post in that forum. I did follow the rules ( I did my best ... ) I was asking which header file header.h to use in CB do I can send serial data in my C++ to a serial port ( Arduino ). I did some research into it and I found a 6 year old posting in the same forum. I will try it and see what happen.
The thing is... get lock-up on the first post is.... Not Nice !
You guys, on this forum, you are nice and helpfull ( in general ). My opinion...
My point AWOL is : my first post, and the tread is lock. ( I can not reply in my own post ) Simply not "Nice". I was lookng for help if CB has an header file do deal with serial ports.
I agree Graynomad... the moderator should give me some slack. Every board is different with differents rules. Maybe my "tone" was a bit "hard". I was surprise and a bit "upset". Mind you the forum got usefull info about Code::Blocks and it is a good ( and FREE ) C++ IDE mind you. I learn from the forums by reading the posts and check the links if it is related to what I need to know or I will save it later for later use. And I search the forums ( sometimes ) for a particular subject or project that I am doing or trying to learn.
