Post-prototype production and licensing?
Hi, I'm developing a prototype device using a Mega2560 and a couple of Adafruit shields. Basically a datalogger with a bit of I/O, towards making a commercial PCB with only the required components.
Because I won't be using original Adafruit or Arduino hardware products at all in the production design, I don't think there's any need to credit either company there, but correct me if I'm wrong.
However, if I keep the publicly available libraries in the final firmware code, is there anything I must do regarding copyright and licensing please?
I assume that I must credit the code library sources, unless I've written them myself perhaps?
Best regards,
Matt.
It all depends on the licence associated with the code and the hardware.
If there is no licence conditions in the code then it is copyright and you can not use it. If there are then read those conditions and see if you can.
The same goes for hardware. Generally if you use someone's product boards in your design then that is OK but if you copy the design that is not. The opposite of what you thought. However I think all Adafruit stuff is open source hardware in which case you are OK but check first.
More than a couple of those libraries may specify GNU license where if you use them, ALL your source has to be Open as well.
