Hello! I'm doing my final paper on IT, basically it's a door unlocking with digital system build on Arduino Mega (2560) and futhermore there's a mobile app build with flutter framework. This app will show all information about some room.
So, I'm sending the fingerprintID from arduino to my web server (hosted on 000webhost) on json format ("id": fingerprintID). I did a lot of test to send a post request with a number and it had worked, but when i try to run all the code (sensor+servo motor+post request) together it didn't work...
here's my test_ethernet code, to run standalone:
#include <Ethernet.h>
#include <SPI.h>
#include <ArduinoJson.h>
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x01 }; // RESERVED MAC ADDRESS
EthernetClient client;
int id = 90;
char server[] = "analyseroom.000webhostapp.com";
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1);
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
const size_t capacity = JSON_OBJECT_SIZE(1);
DynamicJsonDocument doc(capacity);
doc["id"] = 101;
serializeJson(doc, Serial);
if (client.connect(server, 80)) {
Serial.print("Connected to server on: ");
Serial.println(client.remoteIP());
client.println("POST /index.php HTTP/1.1");
client.println("Host: analyseroom.000webhostapp.com"); // or generate from your server variable to not hardwire
client.println("User-Agent: Arduino/Mega");
client.println("Content-Type: application/json");
client.println("Connection: close");
client.print("Content-Length: ");
client.println(measureJsonPretty(doc));
client.println();
serializeJsonPretty(doc, client);
Serial.println(client.connect(server, 80));
my main code:
#include "functions_&_InitStates.h"
#include <SPI.h>
int id = 90;
initSetup();
getFingerprintIDez();
open_close_door();
if(post) {
doc["id"] = fingerPrintID;
client.println();
post = false;
my functions_&_InitStates.h code:
#include <Adafruit_Fingerprint.h>
#include <Servo.h>
SoftwareSerial mySerial(10, 11);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
const int pinoServo = 8;
int fingerPrintID = 0;
Servo motor;
bool found = false, post = false;
void initSetup() {
motor.attach(pinoServo);
while (!Serial);
delay(100);
Serial.println("\n\nTeste de autorização por digital!");
finger.begin(57600);
delay(5);
if (finger.verifyPassword()) {
Serial.println("Sensor reconhecido!");
Serial.println("Não foi possível encontrar o sensor :(");
while (1) { delay(1); }
finger.getTemplateCount();
Serial.print("Existem "); Serial.print(finger.templateCount); Serial.println(" templates no sensor!");
Serial.println("Esperando por uma digital...");
void open_close_door() {
if (found) {
motor.write(128);
post = true;
found = false;
delay(8000);
else {
motor.write(45);
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Imagem tirada");
case FINGERPRINT_NOFINGER:
Serial.println("Nenhuma digital detectada");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Erro de comunicação");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Erro na imagem");
return p;
default:
Serial.println("Erro desconhecido");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Imagem convertida");
case FINGERPRINT_IMAGEMESS:
Serial.println("Imagem irreconhecível");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Informações da digital inexistentes");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Digital reconhecida!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Digital não reconhecida :(");
return p;
return p;
// found a match!
Serial.print("ID encontrado: #"); Serial.print(finger.fingerID);
Serial.print(" com número de série "); Serial.println(finger.confidence);
//found = true;
//fingerPrintID = finger.fingerID;
return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
if (p != FINGERPRINT_OK) {
Serial.println("Digital não válida!");
found = false;
return -1;
// found a match!
found = true;
Well why the ethernet code runs standalone, but when it is with the whole code it doesn't?
