Hi, I'm new here and I need some help regarding consuming rest apis.
I have managed to set up an API with OAUTH2 on Azure. I want both my Arduino and Android application to be able to consume this API. To do this, they first need a Bearer token. I have been able to succesfully make a request with postman to get this token so that I then can make authorized requests with that token. Below is the Curl code for the postman request. (I have replaced the actual secrets with dummy data, but you get the idea)
curl --request POST \
--url https://login.microsoftonline.com/CLIENT_ID/oauth2/token \
--header 'Cache-Control: no-cache' \
--header 'Content-Type: application/x-www-form-urlencoded' \
--header 'Postman-Token: XXX' \
--header 'content-type: multipart/form-data; boundary=----WebKitFormBoundary7MA4YWxkTrZu0gW' \
--form grant_type=client_credentials \
--form client_id=YYY\
--form 'client_secret=ZZZ' \
--form 'resource=https://XYZ.azurewebsites.net
Running this request in postman yields the following response:
"token_type": "Bearer",
"expires_in": "3600",
"ext_expires_in": "0",
"expires_on": "1535466063",
"not_before": "1535462163",
"resource": "https://XYZ.azurewebsites.net",
"access_token": "ACCESS_TOKEN"
Now I can use this access_token to do "regular" requests with, I have confimed that it works with Postman. However when I try to do this request on my arduino, I don't get any response at all. I have tried using ESP8266HTTPClient and the ESP8266RestClient client but both yield similar results. Below is my code for both of them.
static RestClient restClient = RestClient("");
restClient.begin(WIFI_SSID, WIFI_PWD);
String response;
restClient.setHeader("Content-Type: multipart/form-data");
restClient.setHeader("Content-Type: application/x-www-form-urlencoded");
restClient.setHeader("Cache-Control: no-cache");
char* payload = "grant_type=client_credentials&client_id=YYY&client_secret=ZZZ&resource=https://XYZ.azurewebsites.net";
int statusCode = restClient.post("https://login.microsoftonline.com/CLIENT_ID/oauth2/token", payload, &response);
Serial.print("Status code from server: ");
Serial.println(statusCode);
Serial.print("Response body from server: ");
Serial.println(response);
//Testing the regular client
HTTPClient http;
http.begin("https://login.microsoftonline.com/CLIENT_ID/oauth2/token");
http.addHeader("Content-Type", "multipart/form-data");
int httpResponseCode = http.POST(payload);
String response1 = http.getString();
Serial.println("Regular:");
Serial.println(httpResponseCode);
Serial.println(response1);
If I look in the output, it writes:
Status code from server: 0
Regular:
-1
These are some considerations I have been thinking about:
The URLS are using HTTPS and not HTTP. Could it be this encryption that causes these issues? Do I need to supply some kind of CA certificate?
CORS, though I tried disabling CORS completely in the API and it did not help.
One of my keys in the form data (not seen here as I replaced it with dummy data in this post) has a '=' in them. Could this mess up the form data? Do I need to escape these characters?
The code 0 and -1 suggest that there is an error sending the request, I just don't know why! Do anyone have any suggestion on what I could try here?
